Old 07-20-2018, 03:26 AM
ORIGLS6 ORIGLS6 is offline
If it's on the Corvette, check your grounding.
Old 07-20-2018, 03:27 AM
Checked the # 2 wire with an ohm meter, and compare with others? Not likely you got two bad ones, but possible.
Next step is kind of a pain, but assuming you have put an ohm meter on the two (2) plug wires you have tried, and they both show good, next step is to pull the distributor, put it in 180 out. Rotate all the wires 180. Start it up. If #3 now has a weak spark, you have pinpointed the distributor as the issue. If #2 still has weak spark, you have eliminated the distributor as the issue. Not likely the coil if it only affects one cylinder.
If you don't have a spare distributor laying around, I would be glad to send you a functioning one (won't be curved exactly right for your car, but will at least let you know if it is the distributor.
DarrenX33 (07-20-2018), PeteLeathersac (07-20-2018)
  #23
Old 07-20-2018, 11:33 AM
DarrenX33's Avatar
This is on my Corvette.
1969 Z28
1972 Corvette
Old 07-20-2018, 02:38 PM
67 Nova Boy's Avatar
Have you replaced your spark plugs...not uncommon to have a plug or two go bad.
Dave
67 Nova Boy
Old 07-20-2018, 10:51 PM
DarrenX33's Avatar
Holy cow what a nice offer, and I very much appreciate that.. I do happen to have a spare distributor here with me. I am going to try and put it in. I will also consider the experiment you mentioned here. I think I will be able to solve this soon.
1969 Z28
1972 Corvette
Old 07-20-2018, 10:53 PM
Carolina Dreamin' Carolina Dreamin' is offline
Check your messages, Tom
Old 07-22-2018, 03:22 PM
DarrenX33's Avatar
Ok. It was the distributor. I dropped in my old Unilite and it ran great. I have a thought as to what is wrong with it but I will wait until it is looked at. Sending it back to be checked out.
1969 Z28
1972 Corvette
Old 07-23-2018, 05:29 AM
Kurt S Kurt S is offline
Originally Posted by 427_Rat View Post
If one lobe on the distributor cam (for #2 cyl.) was wore down, might prevent spark at low RPM and allow a weak spark at higher RPM when points "bounce"...possibly?
If it was a bad lobe, I don't know that the distributor machine would have caught that.....
Kurt S - CRG
Old 07-23-2018, 01:45 PM
Steve Shauger's Avatar
Administrator
Also when it was being rebuilt it most likely would have been found.
www.yenko.net
www.vintagecertification.com
Old 07-23-2018, 04:54 PM
L78steve L78steve is offline
Yes it would. You look around the whole dial and you can see the spark events of each lobe.
If one lobe is worn it would show a late spark on that lobe.
