Old 05-25-2020, 04:27 AM
1967Z28's Avatar
1967Z28 1967Z28 is online now
The Chevelle unit and Camaro unit both use the same A226CW filter. The cowl plenum shown in your post at the top of this page appears to be a repro which uses the more commonly available 17" diameter lid. It has a rubber seal in the outer groove whereas the real cowl plenum lid is 16-3/4" in diameter and does not have a rubber strip for sealing to the base. The "697' filter will fit with the larger diameter lid because it was designed to use that filter in the first place. The larger diameter lid is used for the repro because it looks close enough that most people don't catch it, uses a commonly available filter, and means there is one less piece to have to tool up to get made.
The Following 2 Users Say Thank You to 1967Z28 For This Useful Post:
nova7579 (05-25-2020), PeteLeathersac (05-29-2020)
Old 05-27-2020, 02:44 AM
resto4u resto4u is offline
Is NKR still in business? Does he have a website?
67 Z28, 67 RS/SS 396 Canadian, 73 Camaro Z28/LT Carolina Blue
Old 05-29-2020, 03:36 AM
169indy's Avatar
169indy 169indy is offline
Post
Here is a recent Business Card.
69 Los Z11
68 SS/RS 396/325
68 Los Z28
Old 05-27-2020, 03:17 AM
Copo_Cartel's Avatar
Yenko Premier Member
I bought the last two second design White ink stamped 226 CW filters from Steve a year ago. I kept one and shared the second one with a fellow member...I recently was able to purchase the first design with the embossed raised lettering. I was glad to finally finish my CP setup
Old 05-28-2020, 11:51 PM
ban617 ban617 is offline
$7,995 is a pretty good return on the $124.00 investment...
