Go Back   The Supercar Registry > Sponsors > Boulder Motorcar
Old 07-08-2025, 10:09 PM
Originally Posted by napa68 View Post
Here is a progress pic from removing the undercoating. I am doing the trans tunnel, as so much of it won't accessible for dry ice blasting once it's all together. As you can see, there is a bunch of tedious removal yet to go.
I should have the transmission back tomorrow, and hopefully the clutch and flywheel by the end of the week.
----There must be a reason to undercoat a fiberglass car. Guessing to protect the frame, etc., but what a pain. Feel for yah! All that stuff on the shifter assembly couldn't have helped any attempt at any kind of speed shifting....Bill S
napa68 (07-08-2025)
  #22
Old 07-08-2025, 10:15 PM
TimG TimG is offline
Good job, Tim, it looks great. They hit everything with undercoat on a fiberglass car on those that I've cleaned up. I have no idea why they did that other than the guy doing the undercoating had no idea what was fiberglass and what was not.
napa68 (07-08-2025)
  #23
Old 07-10-2025, 07:42 PM
Nasblu's Avatar
Nasblu Nasblu is offline
Beautiful can't beat a good original 62 Corvette. Here is our 1962 Original Fuelly 26K original miles all original except one old Lacquer repaint in 1972 and the vintage rocket RPM wheels
The Following 16 Users Say Thank You to Nasblu For This Useful Post:
1967 4K (07-10-2025), 1967Z28 (07-11-2025), 1969L89 (07-12-2025), 67since67 (07-10-2025), 69Z11Pacer396 (07-15-2025), big gear head (07-11-2025), dykstra (07-11-2025), MosportGreen66 (07-13-2025), napa68 (07-10-2025), PeteLeathersac (07-11-2025), ragtop (07-10-2025), roadster (07-14-2025), RPOLS3 (07-11-2025), scuncio (07-11-2025), Steve Shauger (07-10-2025), Tenney (07-11-2025)
  #24
Old 07-10-2025, 07:48 PM
napa68 napa68 is offline
That gives me urges
Nasblu (07-10-2025)
  #25
Old 07-11-2025, 09:37 PM
----This is the way a 62 should be be set up as far as I'm concerned. Love the wheel and tire combo. That puts your 62 over the top for me....Bill S
Nasblu (07-12-2025)
  #26
Old 07-11-2025, 09:54 PM
scuncio scuncio is offline
Looks perfect, can you share the tire sizes?
Nasblu (07-12-2025)
  #27
Old 07-12-2025, 01:41 AM
Nasblu's Avatar
They are 670-15 tires.
The Following 3 Users Say Thank You to Nasblu For This Useful Post:
olredalert (07-12-2025), ragtop (07-12-2025), scuncio (07-12-2025)
  #28
Old 07-12-2025, 04:10 PM
While the transmission took a bit longer than anticipated, it is done and on the way back. I should have it Monday. The blocker rings on 2nd and 3rd were toast, and the front bearing was not all to healthy. 2nd gear itself did not look too bad, but elected to replace it with an NOS unit. Surprisingly, the shafts were MINT! Tom expressed some concern over that if the car was used as intended. With a little luck, this should be back in service EOD Monday, or Tuesday morning.
I still see spots of undercoating I forgot how much Tom likes to use gasket sealer to dress the gaskets. At this point, what's a little more clean up work??
The Following 6 Users Say Thank You to napa68 For This Useful Post:
dykstra (07-13-2025), olredalert (07-12-2025), PeteLeathersac (07-12-2025), Roger M (07-13-2025), RPOLS3 (07-14-2025), Tenney (07-13-2025)
  #29
Old 07-14-2025, 01:29 PM
When can I have it :-)
The Following 4 Users Say Thank You to Charley Lillard For This Useful Post:
dykstra (07-15-2025), napa68 (07-14-2025), RPOLS3 (07-14-2025), Tenney (07-16-2025)
  #30
Old 07-14-2025, 10:30 PM
tom406 tom406 is offline
Charley's back! Looking to buy cool stuff he doesn't need. Must be feeling better
The Following 4 Users Say Thank You to tom406 For This Useful Post:
dykstra (07-15-2025), earntaz (07-15-2025), napa68 (07-15-2025), Tenney (07-16-2025)
