Old 10-25-2003, 03:17 PM
Zedder's Avatar
Zedder Zedder is offline
Default 1967 Z-28 Parts Wanted
Looking for '67 Z-28 parts: 266 distributors, DF wheels, 610 intakes, cowl plenum air cleaners, 6764 and 822 cranks, MO and MP blocks, etc. Thanks! [img]/ubbthreads/images/graemlins/[/img]
Mark
Old 11-10-2003, 11:53 AM
TDW TDW is offline
Default Re: 1967 Z-28 Parts Wanted
Mark...There is a NOS crank on ebay today. Says it is a 67 Z28.
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
Old 11-10-2003, 12:55 PM
Zedder's Avatar
Thanks Tony...I'll check that out!
Mark
Old 11-10-2003, 06:11 PM
Mark, You should be able to use a nice 283 crank. They are steel and small journal. Good Luck! Sam
Old 11-10-2003, 07:12 PM
68z302 68z302 is offline
Sam,
Although the 283 crank will fit it all depend how picky you are about your resto.
The bolting flange for the flywheel is different on a 302 VS a 283 crank. I can't remember which is which one has a bolting flange that is a full circle, the other has a notch in it. Plus the Z28 crank is tuffrided.
Rob
'68Z, original drive train
AS1 AO1 D55 J52 U17 U69 Z28
Old 11-10-2003, 07:50 PM
Rob, You are correct. They were tufftrided. Most off that wears off in time. I never really saw a 302 or LT1 crank where that really mattered. I believe that the 1967 302 crank is a circle with a V cut into it. Anyhow it would all work. There are a couple cranks on e-bay and also I think there is a harmonic balancer available where the key way does line up with the timing mark. The block can be a 4 in bore job with small journals, or you can buy bearing spacers if a small journal is not available. To me the internal parts arn't as important to a resto. as the bolt on parts, as long as it is a REAL 302 with the correct compression. I was hard pressed to get 30 over pistons for my 1969 Z. We had to fly cut a set of TRW 12:1's. There are manufactures out there: Venolia, C+P etc, but are around $800.00 a set. (forged) Correct #'s and date carb, intake, distributor,heads, pulleys, fan, valve covers, correct heads on the intake bolts correct coil etc. is what I try to get first. Correctly dated block is important to me also. Cams, rods,whatever crank I can get 1967 Z original first choice if it is good and reasonable, or I could live with a nicely preped 283 crank. Just my opinion. Sam [img]/ubbthreads/images/graemlins/biggthumpup.gif[/img]
Old 11-25-2003, 10:16 AM
TDW TDW is offline
Mark...There is an ad on Team Camaro this morning you may be interested in. Guy thinks he has a 67 Z28 block and crank. His name is Don. 509-276-6090.
Tony
55 Nomad Gasser
70 SS 427 Nova
Michigan/ Florida
Old 11-25-2003, 12:17 PM
Zedder's Avatar
Thanks Tony! Please do me a favor and send me a PM next time...the vultures are already circling [img]/ubbthreads/images/graemlins/smile.gif[/img]
Mark
Old 11-25-2003, 12:21 PM
TDW TDW is offline
OK Mark...will do.
Tony
55 Nomad Gasser
70 SS 427 Nova
Michigan/ Florida
Old 11-25-2003, 12:45 PM
resto4u resto4u is offline
mark, im very hungry and going in for the kill! "vultures" [img]/ubbthreads/images/graemlins/haha.gif[/img] Roger
67 Z28, 67 RS/SS 396 Canadian, 73 Camaro Z28/LT Carolina Blue
