Old 12-30-2003, 11:31 PM
zgator zgator is offline
Default Re: 72 Lemans ?
Man,maybe this is a 71?was told it was a 72.The louver things are on the front fender right behind the wheel well.There is no endura front end.I di have the front valance here at my house if there is a way of telling the year from this please tell me what to look for.It is NOT a T-37.that much I know because a friend of mine had one many yrs. ago.I did get the front left grill and it only has the Pontiac emblem on it.I would like to get as many parts off this car for people who could use them.I'm not that up on these cars to know just how much is out there repo and such.
Old 12-30-2003, 11:35 PM
Steve_Hoog's Avatar
Steve_Hoog Steve_Hoog is offline
Just get your VIN number, would be the easiest and most accurate.
Old 12-31-2003, 12:02 AM
JLP JLP is offline
'71 has a plastic header and '72 has a metal header. Also front valance panel is body color on '71 and chrome on'72. Also check the emissions sticker on the radiator shroud or radiator support panel as it will tell you the original engine and year.
The 6th number of the vin is the year.
Someone could have put a '71 front clip on a '72 as '70-'72 can be interchanged if you do the entire front clip.
Don't just throw away those fake louvers as they sell for about $17 each thru the restoration companies. Cid should be on rocker panel unless 6 cyl or 455.
Almost forgot, rear valance panel is metal in '71 and plastic in '72.
JLP
Old 12-31-2003, 01:18 AM
Belair62 Belair62 is offline
Hey COPO..wasn't it a NACA duct ?
Old 12-31-2003, 03:00 AM
copo9566aa copo9566aa is offline
Thanks Belair62
NACA
Old 12-31-2003, 03:08 AM
NACA stands for something..I forgot what though...
Old 12-31-2003, 04:21 AM
JLP JLP is offline
Kinda like all the rest of the TLA's and FLA's that get tossed around.
JLP
Old 12-31-2003, 04:50 AM
JLP,rocker panel says 350.the rear valance is metal.I know this because it is all bent up and trashed,so I guess it is a 71.
Old 12-31-2003, 08:40 AM
JLP JLP is offline
Also check the vin as the 6th # is the year.
JLP
Old 12-31-2003, 08:35 PM
GOAT72 GOAT72 is offline
If anyone needs a set of '72 air extractor vents for the front fender, I have a set in good shape, but without the little black plastic grill inserts.
I'll let 'em go fairly cheap.
PM me if you need 'em.
~GOAT72
