Old 07-09-2016, 04:22 AM
bigsixman bigsixman is offline
Default Re: Tonawanda small block?
I have a friend that purchased a 1969 El Camino that he ordered new with a 350/255 hp motor with a Hd 3 speed transmission and it was built in the Tonawanda engine plant. I do remember a Tonawanda valve cover sticker on the end of the passenger valve cover.
69 camaro X11, 56,000 miles, original HO paint
67 camaro SS/RS, Butternut yellow, bench, fold down
Old 07-09-2016, 03:14 PM
ted ted is offline
Here we go. 3956618 L27 8 block suffix coding TO 111 HD Vin 19130xxxx with 2bbl 7029114 on intake 3916313 dated A9 9 - 3932441 heads dated A7 9 - 3927170 water pump dated A30 9 - distributors 111481 or 955 have dates not condusive to build date or me listing has an error(s). Gonna have to take a wee peek..
Hope this helps on the Tonawanda thread.
Ted
Old 07-09-2016, 04:29 PM
bergy's Avatar
bergy bergy is offline
The Tonawanda foundry cast big blocks on mold line 1 and small blocks on mold line 2. Line 1 produced about 30% fewer blocks than line 2. So that was the mix. All went next door to the Tonawanda motor plant. However, Tonawanda blocks (unmachined small blocks) were sent to Flint V8 for machining/assembly when Saginaw gray iron ran short of capacity - this was rare.
Old 07-11-2016, 05:13 AM
red67 red67 is offline
Here are some further photos of my Tonawnada block. Looks like it went down conveyor 1.
Old 07-11-2016, 12:37 PM
bergy's Avatar
The "conv" designations were permanently part of the patterns when they were made. They reflected the planned casting conveyor when the pattern was made (could have been years earlier). They were not "tags" like the date codes & didn't represent which line the mold was actually made on. Remember the rule of thumb - iron patterns (which these were) typically lasted 100,000 molds before refurbishing. Aluminum patterns lasted 10,000 molds. Your block was cast off of pattern #11 in that family of patterns - which could have been in production for a long time.
the casting lines were
Line 1 - M4 Blocks
Line 2 - small blocks
Line 3 - M4 heads and all intakes
Line 4 - small block heads
Line 5 - water pumps, oil pumps, bearing caps, & misc. lower volume parts
Line 6 - same as line 5
Line 7 - was removed in early '60s
Line 8 - all brake drums
Old 07-11-2016, 03:18 PM
Thanks for the good info. I always wondered what these numbers meant but nobody to date has been able to give me the specifics. The intake and heads are also Tonawanda.
Old 07-11-2016, 08:12 PM
novadude novadude is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: bergy</div><div class="ubbcode-body">The &quot;conv&quot; designations were permanently part of the patterns when they were made. They reflected the planned casting conveyor when the pattern was made (could have been years earlier). They were not &quot;tags&quot; like the date codes &amp; didn't represent which line the mold was actually made on. Remember the rule of thumb - iron patterns (which these were) typically lasted 100,000 molds before refurbishing. Aluminum patterns lasted 10,000 molds. Your block was cast off of pattern #11 in that family of patterns - which could have been in production for a long time.
Line 1 - M4 Blocks
Line 5 - water pumps, oil pumps, bearing caps, &amp; misc. lower volume parts
Line 8 - all brake drums </div></div>
Great info. Its always fascinating to learn how they actually built these things (to me, anyway).
Old 07-15-2016, 05:00 PM
Line 1 - M4 Blocks
Is this mold, T11, only used for casting 352 as the casting number is also not a tag? Mold T11 for casting 352. My understanding is that casting 352 was used for 327 and 350 in 1967 only so this block could have had a very limited production run. Alvin Colvin in his book states that he is not sure when this casting was used and thought it was a limited run used late in the model year but the September 1966 casting dates are wrong for that. I believe that Tonawanda stepped up small block production in the fall of 1966 because there was a shortage of the new 350 engine then. In the fall of 1966 you could not buy an over the counter 350 engine or parts. You could only get a 350 engine via warranty and a serial number had to be provided to the parts system. This is stated in GM docs from the era.
Old 07-15-2016, 05:46 PM
bergy's Avatar
That pattern, T11, would only be used for the part number on the cope. &quot;T&quot; is for Tonawanda MCP and it's the 11th pattern in that series. It's possible to have other &quot;T11&quot; patters in another series of blocks. The part numbers were not changeable &quot;tags&quot; like the date inserts were.
