Go Back   The Supercar Registry > Dealer Specific Discussion > Berger Chevrolet
Old 02-20-2007, 06:17 AM
Default Re: '68 Berger Z/28 brought back
I see a bent rod in the upper right..drop a valve?
Old 02-20-2007, 07:08 AM
GreenLS6 GreenLS6 is offline
Hydro locked... oouch!
Scott said it fired and ran. Not good - but ran.
Tim Clary
68 RS/Z28
69 Olds Cutlass S
70 Chevelle SS LS6
70 AMX 390 Go-pack
71 Torino GT 429cj
Old 02-20-2007, 05:11 PM
YENKO DEUCE REGISTRY's Avatar
What the???.... Hydraulic'd??
Marlin
Old 02-20-2007, 10:31 PM
Air compresses, fuel or water does not. It either lost a head gasket and ate a cylinder full of coolant, or had a stuck needle and seat filled a cylinder with enough fuel- it fired on one cylinder came around and stopped on that one. Ran thru a car wash while running ???
I say OUCH either way!!
Tim Clary
68 RS/Z28
69 Olds Cutlass S
70 Chevelle SS LS6
70 AMX 390 Go-pack
71 Torino GT 429cj
Old 02-20-2007, 10:41 PM
ORIGLS6 ORIGLS6 is offline
"Hydraulic'd?? "
We used to see that a lot with my friend's '63 FI Corvette. The fuel blocks on those units were the culprit and would leak fuel into a cylinder. When the engine fired quickly, (which didn't happen often)if the cylinder containing the fuel was on a compression stroke............ TROUBLE!
Old 02-21-2007, 12:49 AM
Denis Denis is offline
totally cool. congrats.
Old 02-23-2007, 03:42 AM
nice... nice cowl plenum hole as well... beats the 1000 drill holes and a chisel I have seen on some... LOL
Old 03-06-2007, 05:55 AM
JRSully JRSully is offline
we used to see that with guys who bought brand new race boats with no experience driving them ,brought them up to speed and then slammed the throttles shut, water would shoot up through the water jackets and load the cylinders, end of ride...
71 Porsche 911 Targa
Old 03-08-2007, 06:42 PM
Ended Rather Quickly....
Old 03-21-2007, 08:27 AM
Finished the brake system today. The 4 piston calipers came out great- Calipers online did a great job. The prop. valve and distribution block from RIGHT STUFF I have to say different on! Niether piece looked even close when I got them. Ended up disassembling ,blasting and replating the old stuff. Thought I had the wrong power booster because there was no delco stamp,Then I saw the 8515 stamping and reused it.
Starting on the dash assembly next. Want to have done and drivable for the BERGER show and reunion.
Tim Clary
68 RS/Z28
69 Olds Cutlass S
70 Chevelle SS LS6
70 AMX 390 Go-pack
71 Torino GT 429cj
