Old 06-20-2009, 01:56 AM
Default Re: Roof Deuce Restoration
Couple of folks have asked how to separate the plastic buckle cover from the metal section. I figured this out by trial and error and gubered only one sacrificial "lamb".
<font color="blue">Tools and buckle placement. In addition to the larger straight slot screwdriver, I used two putty knifes (you can use whatever is as thin as possible, but still rigid):
Place the corner of a putty knife into the gap as shown in below photos and work the blade down into the gap. This will bow out the plastic side of the buckle cover and release a plastic wedge (molded into inside surface of the plastic buckle cover side) from its seated position in the metal portion of the buckle. You have to press the blade down into the gap with a fair amount of force while wiggling it a bit.
Do the same with the 2nd putty knife on the other side:
Insert your straight blade screw driver into the female opening (easy Verne, Colin, Bruce, etc ) and twist it to separate the plastic cover from the metal buckle:
Here you can see the small wedge shaped nub that seats in an opening on the side of the metal portion of the buckle when the two pieces are pressed together. This is what you are unseating when you insert the putty blade. When putting the buckle back together fit the plastic cover to the metal buckle first at the end opposite of where the metal belt spade inserts to the buckle. Then you can pivot the plastic cover down and snap it into position:
</font>
Old 06-20-2009, 02:02 AM
Took the day "off" to do yard work and car work. All belts and hardware have been restored/replated and are ready to be put back in the Nova:
Old 06-20-2009, 02:07 AM
m22mike's Avatar
m22mike m22mike is offline
Very nice Sam...
Old 06-20-2009, 02:31 AM
I agree...also a very nice display photo as well (all in a circle)
Old 06-20-2009, 02:39 AM
DarrenX33's Avatar
Fantastic!
1969 Z28
1972 Corvette
Old 06-20-2009, 03:04 AM
MosportGreen66's Avatar
Nice stuff Sam. Now you have another request... post photos of your garage please. I am in the process of planning a new floor (paint, UcoatIt, LockTile, etc) and would like to see your set up.
Thanks,
Old 06-20-2009, 03:42 AM
WILMASBOYL78's Avatar
Sam, you can comb your hair in those buckles...nice job.
wilma
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
Old 06-20-2009, 04:50 AM
enio45 enio45 is offline
nice work....how much yard work did you get done? :-)
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 06-20-2009, 04:54 AM
x  Baldwin  Motion's Avatar
Nice pictures, really nice. How much yard work were you thinking about while you did this cute display?
Old 06-20-2009, 05:16 AM
We are all proud of ya!
