Old 01-18-2023, 04:33 AM
Rolling in Style: The Story of Pontiac’s 8-Lug Wheels, 1960-68
https://macsmotorcitygarage.com/roll...68/#more-96557
The Following 13 Users Say Thank You to Lee Stewart For This Useful Post:
67 Nova Boy (01-18-2023), Dave Rifkin (01-18-2023), downunder1 (01-18-2023), dykstra (01-18-2023), flyingn (01-18-2023), grantprix (01-18-2023), Keith Seymore (01-18-2023), L78_Nova (01-18-2023), markinnaples (01-18-2023), olredalert (01-18-2023), PeteLeathersac (01-18-2023), Tenney (01-18-2023), YenkoYS-199Stinger (01-18-2023)
  #32982
Old 01-18-2023, 05:22 AM
downunder1's Avatar
downunder1 downunder1 is offline
I just love this type of art work in sales brochures from years gone by.
The Following 4 Users Say Thank You to downunder1 For This Useful Post:
60sStuff (01-18-2023), 67 Nova Boy (01-18-2023), grantprix (01-18-2023), markinnaples (01-18-2023)
  #32983
Old 01-18-2023, 11:58 AM
Keith Seymore's Avatar
Awesome!
I've loved these wheels for a long time -
'63 LeMans Convertible
'63 Grand Prix
'74 Chevelle - original owner, 9.85 @ 136 mph best
The Following 13 Users Say Thank You to Keith Seymore For This Useful Post:
67since67 (01-18-2023), 69M22Z (01-18-2023), Charley Lillard (01-18-2023), downunder1 (01-18-2023), dykstra (01-18-2023), flyingn (01-18-2023), gtomike1967 (01-18-2023), jer (01-21-2023), L78_Nova (01-18-2023), Oldss (01-18-2023), olredalert (01-18-2023), Tenney (01-18-2023), Z282NV (01-18-2023)
  #32984
Old 01-18-2023, 12:10 PM
I just went through quite an ordeal buying tires; if anyone tells you that it's getting tough to buy in 14" sizes - they'd be right.
I had quite a decision matrix going with size, whitewall width, availability and price. I was trying to preserve the size I had on there (P225; or - ideally - go up one to P235) and the thinner 5/8" whitewall.
I couldn't do it. I finally compromised by going down in size (P215) and went to the wider 1" whitewall (you can see the difference in the pic below, front tire being "before" and rear tire "after").
After going through a bunch of vintage pictures I was reminded the 1" white wall was actually a bit more authentic, which made it ok in my mind.
'63 Grand Prix
The Following 5 Users Say Thank You to Keith Seymore For This Useful Post:
67 Nova Boy (01-18-2023), 69M22Z (01-18-2023), downunder1 (01-20-2023), markinnaples (01-18-2023), olredalert (01-18-2023)
  #32985
Old 01-18-2023, 12:18 PM
Originally Posted by Keith Seymore View Post
I just went through quite an ordeal buying tires...
Speaking of which: now that I have the new tires mounted up and put some miles on them - I've encountered an issue where the trim ring is "walking" out of position. It's rotating far enough around the wheel that it is pushing the valve stem over hard and I fear it is going to cut it. I added a little piece of rubber hose around it to protect it as a short term fix.
Anybody ever have this happen, and any potential solutions come to mind? I'm about to add a drop of weld on the wheel to interfere with the clip as it tries to move.
K
'63 Grand Prix
The Following 3 Users Say Thank You to Keith Seymore For This Useful Post:
69M22Z (01-18-2023), downunder1 (01-20-2023), olredalert (01-18-2023)
  #32986
Old 01-18-2023, 12:35 PM
Z282NV's Avatar
Z282NV Z282NV is offline
Is it possible the trim ring is touching the sidewall of tire and the rotation is causing the ring to move? Also possible the clips on the back of the trim rings have seen better days?
I don't think I would strike any arc on the wheel itself until you figure out what is causing the movement. Maybe a bead of epoxy or silicone on the wheel instead.
Maybe these posts need to go some place else to avoid hijacking this thread.
Joe
1969 Camaro
The Following User Says Thank You to Z282NV For This Useful Post:
  #32987
Old 01-18-2023, 12:46 PM
Thank you; yes - and yes. Front rings seem to be worse than rear. Maybe JB weld would work.
I thought about that - but - since the title of the thread is "You Can't Make This Stuff Up!" and you literally can't make this kind of thing up - I figured it was perfectly appropriate to keep it going here.
No disrespect to Lee but to me this whole thread is one big hijack. And I love it.
'63 Grand Prix
Lee Stewart (01-18-2023), olredalert (01-18-2023), Z282NV (01-18-2023)
  #32988
Old 01-18-2023, 12:53 PM
Not a problem guys - discuss all you want
Keith Seymore (01-18-2023), Tenney (01-18-2023), Z282NV (01-18-2023)
  #32989
Old 01-18-2023, 04:12 PM
I have dealt with "hubcap walk" many times over the years. Steel wheels flex a little bit with every rotation. That creates a vibration on the retainer tabs and makes the hubcap (or in this case, the trim ring) walk around the wheel. Kind of like your old vibrating electric football game. I have seen it get so bad it actually rips the valve stem out, or at least over far enough that it pulls partially loose and starts leaking. Some Studebakers from the 50s are especially prone for two reasons. 1. The wheels are thinner than most, and flex more than most, and 2. The tabs are permanently attached to the wheel on some models instead of the cap.
I have cured many of them by just bending the tab to give it a bit more bite.
Look on your wheels where the tabs contact. I think you will see where the scratches have moved a bit over time as it rotates. YMMV.
  #32990
Old 01-18-2023, 05:44 PM
downunder1's Avatar
Awesome!
They are the best factory wheel ever on a standard production car, IMO.
67 Nova Boy (01-18-2023), 67since67 (01-18-2023), Lee Stewart (01-18-2023), olredalert (01-18-2023)
