Old 04-21-2020, 02:34 PM
With a new flywheel, clutch and pressure plate installed on the DZ-302, we finally got some decent weather here this week and I rolled the motor outside to hit it with a coat of orange paint so the engine and bell would match up color-wise. I painted the bell last week and this week I painted the block while dusting the edges of the intake (especially around the corners) as the factory often over sprayed these parts back in the day. In mounting the bell housing and the block, I searched around here and also found a nice set of bell housing bolts with dog bone head markings to button it up.
Also, while finding out last fall that the driver's side cover was in fact a service dated part number that must have been changed, I had not removed the passenger side cover until I painted the motor this week. Turns out it has the correct 3932417 valve cover and would in all likeliness be an original from late 69. I did find a single cover last week to correct the other side and I'm now looking for a set of original O rockers as they were changed when the motor was rebuilt back in 2015. That being said, I should be ready to drop the driveline back in during the next week or two and get it running again. Hopefully, I will be driving it in the next few weeks as long as other interruptions are kept at bay. Life's been dealing me with a few delays lately. (lol)
Installed a 26-lb billet flywheel, performance clutch, and pressure plate. ARP hardware was used.
Finally pulled the passenger side cover to find it was actually the right #3932417 part number.
Here's the 403 bell housing after it was painted and matched up to the block using correct original hardware.
While painting the original block, I dusted the edges of the intake both front and rear. Valve cover edges will be dusted later.
Dry fitting the restored exhaust manifolds and smog rails after coating them with high temp VHT clear.
Old 04-21-2020, 02:56 PM
Here are a couple more shots of the motor before I detail some small parts, replace the vacuum fitting with an original and paint the water pump bolts. Just little details while getting it ready to drop back in. Later today I am hoping to get back onto the front brakes. I'll paint the calipers and they'll soon be reinstalled with new flex lines and the original front rotors that were lightly surfaced. Still have one frame horn to clean up and the driver's side suspension to clean but that should take too long to get done now that the weather is better. More soon.
Intake and valve cover's to be left showing a little grime, a little age, and some patina. Trusting the exhaust manifolds will blend in over time.
Here's the front pad left bare from any new paint. Late original block cast J-13-9 and stamped V1021DZ
Restored J-10-9 water pump being mocked up. I need to paint the bolts now.
The last of the front end to be cleaned up and detailed before the brakes go back on. Slowly progressing along.
big gear head (04-21-2020), HawkX66 (04-21-2020), R68GTO (04-21-2020)
Old 04-21-2020, 03:12 PM
ZAPPER68 ZAPPER68 is offline
Yenko Premier Member
Hi Graeme,
I'm sure I have a set of '0' rockers in my stash...from what I remember they are in decent shape.
Cheers
Cal
The Following User Says Thank You to ZAPPER68 For This Useful Post:
NorCam (04-21-2020)
Old 04-21-2020, 04:55 PM
Originally Posted by ZAPPER68 View Post
Hi Graeme,
Cheers
Cal
Sent you a PM Cal.
Old 04-21-2020, 05:03 PM
While on the topic of parts needed...
I'm also looking for a factory clutch inspection cover and the elusive "Stamp Rite" carb to fuel line bracket if I can ever find those.
Shameless Plug
Old 04-21-2020, 08:54 PM
Graeme,
The Inspection cover pictured is for a 621 Bellhousing and not the 403. Dave
67 Z/28 Butternut Yellow
69 Z/28 Rally Green
69 Z11 Pace Car
2010 2SS RS Aqua Blue
68 Z/28 Lemans Blue
C7 Corvette
68 SS Lemans Blue
Old 04-22-2020, 02:41 AM
I pasted the wrong link. Now corrected in the previous post. Thanks
Old 04-22-2020, 08:05 PM
Graeme,
What clutch setup did you go with??
Old 04-22-2020, 08:29 PM
I was going to go with another Hayes but their flywheels were back-ordered. The guy I spoke with at Summit then suggested I go with a RAM Billet flywheel and said these were the hot ticket at 26lbs. He then suggested a RAM Powergrip Clutch Kit and said they sell these 20 to 1 over that of the Hayes Gold. Real reliable clutch disk and pressure plate which is rated for 550hp.
RAM-1511
Flywheel, Billet Steel, 153-Tooth, Internal Engine Balance, 26.000 lbs., 2-Piece Rear Main Seal, SFI 1.1 $239.00
RAM-98760
Clutch Kit, Powergrip, Iron/Organic, 1 1/8 in.- 10-Spline, 10.5 in. $349.00
Old 04-22-2020, 09:21 PM
Graeme,
The new picture of the clutch inspection cover is 67 68 for 69 is slightly different.
Thanxs Dave
69 Z/28 Rally Green
69 Z11 Pace Car
68 Z/28 Lemans Blue
C7 Corvette
68 SS Lemans Blue
