A few weeks ago I managed to find the time to get some work done again on the Chevelle.
When I built the 496 back in 2008, I tried something I'd never done before with the ring package that didn't quite pan out as I'd hoped. After the last drive I decided it was past time to do something about it, so the 496 came back out. (note: this is why I test these things out on my own stuff, not a customers engine) Side-note: I also REALLY wanted to get that 621 bellhousing out of the car. In it's place will be a Quicktime scattershield and block plate. The engine came down and was re-honed, and while I was at it I swapped in a set of new custom Autotec pistons to drop the compression down from 11.2-1 to 10.5-1. (The Autotec pistons also feature a much nicer modern ring package) This will give me a bigger tuning "window" so I can see what (if anything) there is to be had with more aggressive tuning. Everything else remains the same from the previous build, noting the addition of the Stef's oil pan I installed after the engine came off the dyno the first time. I dropped the engine & peripherals off @ Kammers today, the tentative plan is to test some time next week if/when this heat breaks a little (hoping for Wednesday/Thursday). I was planning a pretty extensive series of tests this time around, but the situation on the home front dictates otherwise--even with my now abbreviated itinerary, I'm still probably looking at two days on the dyno to cover the bases I can. Note that I'll be using 100 octane LL Avgas as the baseline fuel. Here's some of the planned tests (in no particular order): 1) Re-establish a new baseline with the engine as it was last in the car/on the dyno save for the change in pistons/rings and the Stef's oil pan. 2) Header test: The existing headers are Hedmans with a 2" primary and 3" collector. Once the new baseline has been established, I will remove the 3" collectors and install a pair of 3 1/2" Schoenfeld collectors. If time allows, I'm also looking to test with a set of 2 1/8" and 2 1/4" headers if Kammers has suitable pipes available. 3) Lash, timing & Jetting loops: I wanted to do this when I had the engine on the dyno the first time, but we ran out of time to get it done. Depending on the outcome of the timing loop testing, I *may* test between 100 octane LL (Avgas) and premium unleaded pump fuel. If the engine wants 38°-40°+ for total timing, I'm not going to bother as I know it won't tolerate the pump gas with that much timing. 4) Spark plug test between non-projected tip and projected tip. (same heat range NGK's) 5) Carburetor test between the 3418 OEM vacuum secondary 855 cfm carb and a conventional Holley LIST 4781 850 cfm double pumper. 6) Ignition test: The engine will be baselined with the OEM points distributor and coil and will NOT utilize the MSD box on the dyno. Afterwards I will install a MSD billet distributor and we will hook up the 7AL unit on the dyno to see what (if anything) is there. 7) Air cleaner test, with and w/o. 8) Intake manifold test: The engine will be re-baselined with the 163 intake with the cut plenum divider. Afterwards I will install a heavily modified Holley Strip Dominator intake (which is destined for another project to be announced later). Next, I will install my Edelbrock UR2X tunnel ram intake and 4779 750 cfm double pumper carbs. Some of the other things I'd planned to test if time allowed: A: Move the cam from a 105° ICL to 109° in an attempt to trade some low/mid power for upper rpm power B: Oil pan test between the Stef's unit and a Milodon 31188 pan. C: Rocker arm test between 1.7 and 1.8 ratios D: Testing the baseline 163 with the cut plenum against a <span style="font-weight: bold"><span style="text-decoration: underline">heavily</span></span> ported 163 I have. FWIW, this will most likely be the "last hurrah" for the Chevelle, at least while it's in my possession. I'll post the results in a new thread in my forum and link to it in this thread. |
Can't wait Eric!!!!
Sam... ![]() |
[img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
![]() 1969 SS396 Post Sedan Delivered to Van-T Topeka KS MCACN Day2 Concourse Gold Award 1965 VW El Lobo Dune Buggy built in the mid 70’s for the Iowa Shriners 1968 Schwinn Orange Krate 1969 Schwinn Pea Picker 1968 Schwinn 5-Speed 1970 Schwinn 3-Speed Deluxe 1972 Schwinn 10-Speed Continental 1973 Schwinn 5-Speed Suburban All Original Paint Bikes |
Just got the call from Bob, the engine's on the dyno and ready to fire.
I'll be out there first thing tomorrow morning. |
I’ve been working out the last few bugs on the Chevelle and I have it pretty close to dialed in, there's still just a tiny bit of part-throttle carb tuning to reel in.
Yesterday I received a new Crane Xr-i ignition module to replace the one I popped back in `06 when I installed the engine in the car--it really helps if you wire them up correctly. [img]<<GRAEMLIN_URL>>/rolleyes.gif[/img] I've also been busy making a home-made advance limiter bushing for the distributor that would allow me to bump up the initial timing a bit w/o having too much total. Anyhow, yesterday I managed to get both items installed. The Crane module really cleaned up the idle (along with the extra few degrees of initial as well) and improved the throttle response. I also got my digital speedometer/e.t. calculator calibrated yesterday, and I made a slight adjustment to the tire pressure on the L60’s. I took it out today for a few laps around the block, and a brief “clear its throat out” romp (just through 1st gear and a quick shift into 2nd). Two things to note: 1) The reduced pressure made a major difference in traction—it didn’t roll them over anywhere nearly as bad as it did before—as a matter of fact, I thought my head was going to wind up in the package tray for a moment....) I can’t believe those things hooked as well as they did. I’m honestly impressed with those tires. 2) Putting it bluntly...this thing’s stupid. [img]<<GRAEMLIN_URL>>/naughty.gif[/img] This is w/o a doubt my all-time favorite build I’ve ever done for myself, and it almost scares me to think that there’s still quite a bit of un-tapped power still waiting in the wings. I really need to get that 4.56 gear out of there though, it’s total over-kill on this car. A 3.73-4.10 gear would be perfect for it. If I can somehow manage to pull it off, I'll try to get a ride-along video done before too long and post it up. |
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: VintageMusclecar</div><div class="ubbcode-body"> The Crane module really cleaned up the idle (along with the extra few degrees of initial as well) and improved the throttle response. </div></div>
Is this compared to points or to the "damaged" Crane module? I keep thinking of moving away from breaker points, but keep talking myself out of it and thinking that any "drop in" system won't outperform points. |
We like video`s [img]<<GRAEMLIN_URL>>/headbang.gif[/img]
69 300 Deluxe Post Sedan Frost Green 69 SS396 300 Deluxe Post Sedan Lemans Blue SOLD 70 Buick Skylark Post Sedan Gulfstream Blue 70 Buick Skylark Post Sedan Burnished Saddle http://m.youtube.com/watch?v=PM3DE8qI2NY https://m.youtube.com/watch?v=Yn4xEmGypUw |
That's compared to the old points. The original Crane module was toast as soon as I wired it backwards (oops).
The Crane system is nice. It has an adjustable built-in rev limiter, and best of all it looks damn near stock, only has one additional wire going to the coil. I have an MSD 6AL box for the car, and it runs so good now I don't think I'm going to bother installing it. |
