Old 12-27-2012, 02:44 AM
69 Post Sedan's Avatar
Default Re: ZL1 # 48 coming to Barrett-Jackson
I might be way off base but is that the original frame to the car? If so, shouldn't it have a proportioning valve metering block for power brakes mounted to the frame?
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 12-27-2012, 03:15 AM
camaromb camaromb is offline
The Canadian title history shows the car was registered in 2006 with no prior title history.
Incorrect/missing/questionable firewall items:
- RS hole in non-RS car
- incorrect cowl induction wiring location, not at the Norwood plant dimple location, LA plant had no dimple to locate.
- missing the cowl induction switch wiring clip hole.
- missing the cowl induction relay screw hole.
- missing the wiring gutter screw holes in the face of the vin-stamped cowl panel.
- missing the factory dimples in the face of the vin-stamped cowl panel, below the pass. side washer nozzle area.
- LA typical cowl foam glued to the top of the cowl on both sides, Norwood plant typically glued them to the underside of the cowl panel.
- missing the sealant around the complete heater box and vin stamped area but sealant is evident on the complete firewall seam and driver's side
firewall area.
Old 12-27-2012, 02:07 PM
bergy's Avatar
bergy bergy is offline
Canadian guys - what kind of ownership documentation do you have to supply in order to register a car in Canada? Import docs? Sale receipt? Any proof of ownership?
Old 12-27-2012, 02:48 PM
supercomp 8.90 supercomp 8.90 is offline
looks like a brake drum on the drivers side? i always get spooked out when ever i see the cowl tag pulled resto or not.
Old 12-27-2012, 04:35 PM
Is there a pic of the vin that ties ZL1 # 48 to these pics ?
Old 12-27-2012, 07:16 PM
huggerorangez28 huggerorangez28 is offline
Charley does the vin always appear on the deck pad on a ZL1 motor? is it every by the oil filter like an iron block?
Only BAD Chevy's
Old 12-27-2012, 07:17 PM
Only BAD Chevy's
Old 12-27-2012, 11:55 PM
quik9r's Avatar
quik9r quik9r is offline
Unless there is some way to tie #48 to those exact photo graphs, this could be any Camaro.
Quik9r
Old 12-28-2012, 12:05 PM
67BelAir427 67BelAir427 is offline
This thread is becoming boring. Four pages of posts about how this could not possibly be the rare #48 ZL1 that the authorities lost track of.
I am heading over to the thread about the #30 Dick Harrell Nova. That one is "undocumented at this time" but has three pages of congratulations on such a rare find. I just hope it's not too late to get in on the group hug.
Old 12-28-2012, 01:34 PM
67Belair427...I posted the # 30 vin pic over on that group hug thread just for you.
