Old 02-11-2013, 10:00 PM
jasonL78 jasonL78 is offline
Default Re: 70 L78 Nova?
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: LIBoomer</div><div class="ubbcode-body">Jason,
Thanks. First place I looked. Mice had breakfast,lunch and dinner in the back seat for quite awhile. The bottom of the seat frame looked like a multiple family apartment complex. Went through it carefully. Nothing.
Todd </div></div>
Bucket seat car, check behind the hard plastic rear cover on each seat. It's a long shot maybe you will get lucky...
Looking for the next project.
Old 02-11-2013, 11:04 PM
LIBoomer LIBoomer is offline
Send a message via Yahoo to LIBoomer
Wilma,
Here's the trim tag. And brake valve.
Old 02-11-2013, 11:09 PM
Jason,
Yes, bucket seats are installed. But, it was born a bench seat car. You are correct about paper work found behind the plastic back on drivers side seat. I found a partial build sheet for my Yenko Chevelle there.
Old 02-11-2013, 11:22 PM
YENKO DEUCE REGISTRY's Avatar
That's a standard black bench interior, I think Legendary is now making the correct seat covers. Make sure you check the upper section of the rear seat for the broadcast sheet - it won't tell you the engine code though, that was only through '69.
Marlin
67 RS Camaro-327/250hp, 2speed Glide, &amp; 3.08 Open (Danny's Ride)
Old 02-11-2013, 11:38 PM
WILMASBOYL78's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: LIBoomer</div><div class="ubbcode-body">Wilma,
</div></div>
So the car was an October build...that brake valve is correct for that period...there were a number of changes mid year (approx jan/70)..your car would have the mechanical throttle arm...instead of cable. It appears there is little doubt this was a real BB car from the factory...that's the great thing about intact survivor type cars...hard to fake that kind of patina.
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
Old 02-12-2013, 12:58 AM
Wilma,
You are correct. This 10B car has the solid throttle arm. My 02B L48 car, has a cable. What knowledge do you have of this door panel? Is this standard 70 with the white horizontal? The L48 has wood grain.
Old 02-12-2013, 01:19 AM
The standard vinyl interior would have a vertical white stripe on the door panel...the deluxe interior has the &quot;faux&quot; wood grain horizontal stripe. The standard interior would not have rear armrests and would have come with a rubber floor mat...no carpet. The attached photo shows the correct #731 interior, rubber mat and std. door panels.
02 Berger 380hp #95
Lots of L78 Novas
70 Orange Cooler
69 Camaro
Old 02-12-2013, 01:52 AM
Wilma,
What do you think of this?
Old 02-12-2013, 01:59 AM
Wilma,
Looked at the interior again. The rear panels match the above style. There are arm rests in the back. I found remnants of carpet pile under the sill plates. Mid year change or different year?
Old 02-12-2013, 02:23 AM
Ok. Just looked at a Nova catalog. That is the Deluxe Interior style. I suppose the interior could have been swapped which may explain the addition of buckets. Must have been done early in its life.
That roll bars been in there for a while.
