Old 03-13-2018, 03:22 PM
----Look up front just after the headers and you will see why he can do this.......Bill S
Old 03-18-2018, 06:02 PM
napa68 napa68 is offline
Got my Wegner Motorsports accessory drive installed. All I can say is WOW!
Steering is mocked up..........
I'll take the opportunity to give a shout out to Ididit. I purchased one of their columns about 7 years ago. The top of the column had become sloppy. When calling them for parts, they asked for the serial number and told me where to find it.
Without asking for dates, proof of purchase.....................asked nothing...........They offered to repair the column, free of charge. All I had to do was ship it to them. What a pleasant surprise.
Tore apart the headlight buckets for blasting and power coat
Old 03-19-2018, 03:10 AM
Kurt S Kurt S is offline
All newer cars have that isolator joint on them and they still hang/dampen the rest of the exhaust.
I'd think you'd hear the exhaust vibrations resonating in the pipes and through the frame. Dunno.
Kurt S - CRG
Old 03-19-2018, 12:30 PM
earntaz earntaz is offline
True ...
Old 03-23-2018, 03:15 PM
yellow wagon yellow wagon is offline
If the only flex point is at that front section and everything else is rigid mounted to the frame I think its still going to break/shear one of the mounts off near the tailpipe. These are long cars and since he's running the pipes all the way out the back, you'd want to dampen the pipes along the way with rubber or even better, urethane. Will create less vibration throughout the cabin as well as allow the tail sections the ability to move around a little as the car is running. Just my 2 cents ...
1964 Chevrolet Biscayne
409 4-speed
Old 03-24-2018, 07:11 AM
I'll add that I worked enough with vehicle NVH issues that I am sensitive to noise transmission paths. Putting rubber dampeners in the joints (sandwich style) so it's not steel-on-steel would help.
Kurt S - CRG
Old 06-10-2018, 12:42 PM
The rest of the mounts have urethane mounts at each point.
Old 06-10-2018, 12:46 PM
Time to catch up..............
The intake tube is finished and getting the wiring, TCM, and ECM placed........
Old 06-10-2018, 12:47 PM
Firewall smoothed and prepped.............
Bottom is coated with bed liner............
Firewall painted................(with correct overspray below seam)
Old 06-10-2018, 12:49 PM
Some detail pics before it get covered up............
How do you like trans mount? Great for isolating vibrations!
