Old 02-19-2021, 05:36 PM
Install - Part IV
The beefy 3/4 shift rod was the one that would present an issue with clearance in the tunnel. It mounts to the outer 3/4 shift leg below the shifter body, and as luck would have it that leg already protruded out beyond the tunnel wall (see image 1 below). I installed the shift rod and wedged it up between the tunnel and the front of the trans side cover. That allowed me to mark the tunnel where 4" of the tunnel would need to be relieved along the back end of the rod (closest to the shifter body).
Instead of pounding or massaging the tunnel outward, I chose to slot the tunnel ahead of the shifter box and this allowed the back half of the shift rod to travel through the side of the tunnel closest to where it would attach to the shifter. After it was slotted, I continued with the sheet metal work and formed a 24ga tapered cover for the outside of the tunnel. This enclosed the slot I made for the shift rod and joined to the front of the shifter box I had just finished. Building this new side cover with a tapered front, it was 7/8" deep at the point where it joined the box, and tapered out to be flush at the leading edge.
Here you can see the outer shift leg for the 3/4 position rod is out beyond the side of the tunnel. This is why it needed to have the side of the tunnel slotted.
I marked out the chalk lines in the tunnel and transferred them through to the inside before making my lateral cuts.
Only the first 4" of the slot would have the rod pass out through the side of the tunnel, but I decided to cover it with a longer tapered box that ran 8" forward of the box.
Cutting a longer slot than needed, a tapered box was made with it being 7/8" deep at the shifter end and feathered out to nothing at the front.
I added a coat of epoxy to the inner seams and once it was all done and welded into place, I sprayed a few coats of black paint to the tunnel side.
GrumpyJeff's Avatar
GrumpyJeff GrumpyJeff is offline
Originally Posted by rszmjt View Post
Graeme, 1 trick we used to do with the adjustment of the rods- once u get the alignment pin to fit we would lengthen the 3-4 adjuster 1 turn. This kind of makes the H patten more pronounced going towards 3 rd gear . This makes the shifter lower internal arms go through a stretched or distorted H pattern favouring it towards 3rd gear, this way when you are slamming gears it does not go through the exact H pattern . It does not effect the neutral position and does not cause binding when just cruising.
Great Tip ! my Dad hooked me up on this trick on a couple shifter installs !!!
Old 02-19-2021, 05:57 PM
Install - Part V
As things wrapped up with the metalwork, I added some sound deadener material to the inside of the transmission tunnel to help with road noise. I will now move on to glue and carpet the sides of the box and will then install a new black loop carpet on the inner floors while trimming around the shifter box. I also found that by cutting down the original SS3 boot, I could install the smaller B4 boot ring. This will provide a clean and correct SS3 boot finish, but on a smaller footprint.
Hoping this helps the next person who wants to install a vintage shifter in a 69 Camaro. More pics when all is finished up next week.
Sound deadener added to cancel out road noise.
It also helps to reduce the amount of heat that transfers up through the floor.
Here's a cut down SS3 shifter boot bought from Summit Racing and fit with a B4 ring from another shift boot I had laying around.
Once the carpet is wrapped around the box, this will provide a nice clean upright finish for the boot.
Old 02-19-2021, 09:18 PM
Sweet! Nice work!
Jason
NorCam (02-20-2021)
  #35
Old 02-19-2021, 09:26 PM
Ryan1969Chevelle's Avatar
What did you “cut down” on the SS3 boot?
Ryan W31
Old 02-19-2021, 10:08 PM
Rumbleguts396 Rumbleguts396 is offline
WOW!!!! Very Nice Work
1969 Camaro SS 396 X66 Lemans Blue
1969 Corvette 427/390 Lemans Blue
The Following User Says Thank You to Rumbleguts396 For This Useful Post:
NorCam (02-20-2021)
  #37
Old 02-20-2021, 12:33 AM
Ryan W31
I cut the top section off the boot Ryan. It was cut along the 5th rib where the only top 4 ribs were left intact for the top of the new box. I then put a smaller B4 ring around the top section of the boot after it was cut down. Pictures are above.
