Old 01-28-2025, 12:12 PM
Zman1969 Zman1969 is offline
Originally Posted by Woj View Post
Just a quick note after rereading the thread. The driver's seat appears to be original, have you tried sending a borescope into the seat back, driver's side? You can remove the seat back release mechanism and fish the scope into the seat. I did find a left 1/3rd build sheet there in my Framingham 69 Malibu. I couldn't remove it, but was able to photograph it.
no haven't done that yet but will eventually too much other "Stuff" goin on but little progress on engine - still needs Intake installed
69 RS/Z 302 VE3 Daytona
69 Chevelle SS 396 375
69 T/A clone LS6/6 speed
90 Formula 350
The Following User Says Thank You to Zman1969 For This Useful Post:
John (02-04-2025)
  #32
Old 01-29-2025, 08:55 PM
Mark2002 Mark2002 is offline
I owned this '69 Chevelle before Zman1969, and I found a partial build sheet under the driver seat and another partial build sheet in the passenger side rear seat back. (which he has now)
Hopefully there is another one someplace else.
The Following 2 Users Say Thank You to Mark2002 For This Useful Post:
John (02-04-2025), Zman1969 (02-19-2025)
  #33
Old 02-14-2025, 11:43 AM
My build sheet was found in the back seat but I did not find it. The guy I bought the car from found it. Nothing on the gas tank, and the front seat had been recovered. My car is a bench seat.
65 Corvette Coupe L78
69 L71 Roadster Survivor
69 Z/28 RS (Sold)
69 Dodge Charger R/T
70 W30 442 Auto Air Survivor
2016 Z06 Coupe M7
70 AAR Cuda (Sold)
69 L78 Chevelle (Sold)
The Following User Says Thank You to sixt9rsx33 For This Useful Post:
  #34
Old 02-19-2025, 09:20 PM
Mark good to know I'll stop looking for anything more I just figured there would be more of it
so these 842 heads are about done they were milled enough intake needed to be milled down .060" and .125" on the ends 3 trips to machine shop anyway its fitting much better, someone did me a favor and had welded up the crossover, glad it wasn't the date that should be on the car
90 Formula 350
dykstra (02-20-2025)
  #35
Old 03-04-2025, 02:25 PM
well, I'm glad that's finally done! now to find a weekend to do the swap the nice thing about a beater is this will only see limited nighttime use its next caretaker can make it pretty.
the drivers head has a plug where temp sender should be and it looks like its been in there a long time and I don't want to break a tool off trying to remove it - any suggestions?
90 Formula 350
Old 03-04-2025, 05:44 PM
That's the same 90005 FelPro gaskets that I always use. I love those gaskets. Be careful with those valve springs. Rust on a spring can cause it to fail.
Zman1969 (03-11-2025)
  #37
Old 03-11-2025, 05:44 PM
those were on heads when bought and I trashed them, just best pic showing the plug I want out headshop installed outers of comp duals for break in
90 Formula 350
big gear head (03-11-2025)
