Old 10-24-2023, 03:01 PM
OneStopRestoration OneStopRestoration is offline
SpeedyB
Its pretty quiet, however the exhaust note is on par. For a little more money you could go solid rollers, to get back lifter tick. I considered that but deicded the hyd roller was my route from now on.
The Following User Says Thank You to OneStopRestoration For This Useful Post:
SPEEDYB (10-30-2023)
  #32
Old 10-27-2023, 01:39 PM
Crossbreed383 Crossbreed383 is offline
Good morning everyone..
Please re-read post #14
I tried to politely give the reason without throwing any companies under the bus, but
hey, looks like multiple people in here have seen the same from said company.
It is a core issue, plain and simple .
Thanks
Custom Cam /Engine Dyno and Spintron Operator at Brian Tooley Racing R@D
84 Mustang/Hertz Rent-a-Car
438CI 5.58@123 8.80@147 On Radials ALL MOTOR
Powered by my 13 year olds engine program
68 NOVA 396-375 HP F.A.S.T. Project
The Following 7 Users Say Thank You to Crossbreed383 For This Useful Post:
67 Nova Boy (04-10-2024), dykstra (04-08-2024), L78_Nova (01-24-2024), Oldss (01-24-2024), olredalert (04-08-2024), PeteLeathersac (01-24-2024), SPEEDYB (10-30-2023)
  #33
Old 01-24-2024, 07:32 PM
RobR RobR is offline
Thanks Pete!
Nick’s post:
Originally Posted by Crossbreed383 View Post
The issue IMO is more to do with insufficient case hardened depth on the cam cores being used. The issue is when the case depth on the nose isn't enough and this is magnified because of spring psi being highest at over the nose of the cam, than on the base circle of the cam .
Certain companies use the same UGL( unground lobe ) cam cores for a multitude of cam valve events, pt numbers , etc . The issue lies in that you harden the lobes during heat treat, but when you try to cut the more than one cam profile, using multiple centerlines or lobe lift( base circle) on the same core ,you end up grinding away too much or even going through the heat treat in some spots.
If the use a specialty UGL for each specific cam then the case depth is set at XX mm of what it needs and you after final grinding you are left with sufficient heat treat depth.
We see it all the time here .
Thanks
The Following User Says Thank You to RobR For This Useful Post:
  #34
Old 04-07-2024, 11:55 PM
I'm building a 327 for my dad's 55 Chevy. I'm using a Comp Cams flat tappet hydraulic cam CS XE284H-10. I took it out of the box and was cleaning it to get it installed and I noticed that the lobes had a rough finish. I put it in my lathe and turned it slow while running a wire brush over the lobes. I used gray ScotchBrite after the brush and the lobes are smooth. I wonder if this has anything to do with the failures. Pictures are before and after. It's hard to tell in the pictures how rough the finish was before cleaning them.
  #35
Old 04-08-2024, 12:16 AM
Before pic looks like 100 grit sand paper. Looks a lot better after, but are you going to trust it, Freddie ?? Was the rough texture case hardening scale ? Seems it couldn't have been machining burrs if it came off with a wire brush.
Old 04-08-2024, 12:00 PM
We are using the new diamond coated lifters on it, so I feel pretty good about it. I have no idea what the junk was that was on the lobes. It wouldn't come off in my mineral spirits tank. The wire brush took most of it off pretty easy. I heat treat metal all the time, and I'm pretty sure that this wasn't scale from heat treating it.
Too Many Projects (04-08-2024)
