Old 09-21-2001, 01:03 PM
JLerum JLerum is offline
Default Re: 2001 Pure Stock Drags
Their you go guys, that tells you what .011 difference in valve lash will do to a really strong motor. I didn't think it would of increased the cranking pressure that much but it had to help the torque curve a bunch on the bottom end.
My hats off to you Pete for your fine tuning skills. How many inches of vacumm did the motor make at normal lash and your revised lash?
Jim
1970 LS-6 Chevelle
Going fast on Goodyear Polyglas.
12.21 @ 115.32 PSMCDR 2009
12.24 @ 114.30 PSMCDR 2010
Old 09-21-2001, 02:35 PM
Chevy454 Chevy454 is offline
Now we are talking! Ok, Jim, so what is the "optimum" compression ratio for the standard L-71/L-72/L-78/LS-6 cam (.520/.520)?
Now, I understand why Pete did what he did with his ZL-1: he needed the lash for the brakes and to make up for the ZL-1's natural lack of a bottom end, both due to the big cam. BUT, I noticed in his L-72 dyno test that he ran a lot of lash as well, not as much as the ZL-1, but still well off of the factory's 24/28 mark.
Pete: did you get the email with the muffler/crossover tests?
Old 09-21-2001, 08:29 PM
Pete, did you have to run the 780 vac sec as your ZL-1 carb? I'm sure it was tough getting the secondaries to open properly. If I remember right, the lowest spring tension is a 6.5" of vacuum. I would assume that when you saw 2" of vacuum you said oh sh!t.
Jim
1970 LS-6 Chevelle
Old 09-21-2001, 08:40 PM
You need to give me some time on finding measurements for the cam as I can't find any information on when the valve actually closes. I have a cam that I'll take over to a buddies cam doctor(measures lobes and gives read outs)and see what it comes up with. If anyone out there has the measurement for an LS-6/L-72/L-78 cam put it on the site. It can not be a measurement at .020 or .050 as these don't qualify. It must be lift off the base circle.
Jim
[Edited by JLerum (09-21-2001 at 03:40 PM).]
1970 LS-6 Chevelle
Old 09-21-2001, 08:56 PM
<BLOCKQUOTE><font size="1" face="">quote:</font><HR>I would assume that when you saw 2" of vacuum you said oh sh!t.<HR></BLOCKQUOTE>
That would probably be MY reaction! Oh, and I am looking for the cam specs...
Old 09-21-2001, 09:33 PM
JoeC JoeC is offline
I don't know what Pete is running but the ZL1 engine is a lot different then a L72.
The ZL1 engine was a L88 with an aluminum block. I have seen different spec sheets on them but according to one spec sheet It used a 850 Holley Double pumper, 12.1 compression, open divider intake manifold, a bigger cam, a transistor ignition system, and some other differences vs the L72.
Old 09-21-2001, 09:42 PM
There are some subtle differences between the ZL-1 and the L-88, but I can't remember off hand which carb Pete was running...I think it was the 850, but I wouldn't swear to it.
Old 09-22-2001, 05:35 AM
Jim. ! 2 inches of vaccum at 1000rpm. With the inreased lash the motor went to 5 inches. It was interesting to note that we had the motor idling at 1000 rpm., increased the lash to .035 and with no other change the motor idled at 1700 rpm. It was nuts. Originally we thought we had a vaccuum leak and ran around the intake with a torch. No increase in rpm. Then we stuck the torch down the carb....no increase in rpm. Man that had us confused. We then stuck the torch tip in the pcv hose, and it picked up about 400 rpm.
Thanks for the tip, I am as we speak looking into a crossover pipe!
Peter
Pete Simpson 1962-2013 RIP
Owen Simpson
Eric Simpson
Old 09-24-2001, 12:12 PM
Duration is the time that a valve opens to the time that a valve closes. On a cam card you get duration on the intake and the exhaust valve. These measurements are usually at certain standard lift values so that you can compare cams. The most important thing to know is when the intake valve closes (use a degree wheel) as this determines how much air/fuel mixture is caught in the cylinder. The later the valve closes the more static compression you need to help the dynamic compression of the motor. The term dynamic compression is the functional compression an engine understands when it is in motion (running). Because of the intake valve closing point being so important, you must build a motor so that the intake valve closes just right for the compression.
In the case of running in a class like Pure Stock Muscle Car Drags it is a little different. When running the (stock) cam you must pay attention to your compression. Design the motor so its compression ratio fits the cam by decking the block, ccing the combustion chambers, and or selecting head gasket thickness. The stock cam is defined by the rules so you must make the compression fit the cam. Do not think that more compression is always better because you can have too much compression for a cam. A good example would be the Buick Stage 1. The PSMDR allows you to blue print the motor to NHRA specs. The specs submitted to AMA would allow this motor to push almost 13.0 to 1 compression. The stock cam valve duration would keep you from using all this compression advantage and would be less than competitive.
To fine tuning a solid lifter cam motor you can change the intake valve closure 2 ways. The first would be on how you degree the cam during setup with the timing chain (advanced or retarded). This is the most effective way to move intake valve closure. When the cam is advanced the intake valve is closed sooner, increasing cylinder pressure effecting low-end torque. Retarded the cam closes the intake valve later and helps top end horsepower. Again this is because better high RPM cylinder filling.
The second would be adjusting lash. (IĂm finally answering your question) The looser the lash the more slack the camshaft lobe must take up before opening the valve. The lifter will have traveled farther up the lobe delaying the valve opening and closing the valve sooner on the back side of the camshaft lobe. In effect you have removed some duration. The other unfortunate result is you have lost lift. Extra slack in the valve train keeps the lobe from displacing its full lift to the valve. This is bad because we know that BB Chevys love lift.
If you are really able to sit on a dyno for an extra day, a lash loop should be tried. Isolate the intake valves and increase/decrease their lash in .004 increments to see how the engine responds. Then try the same thing with the exhaust. This will tell you how well youĂve chosen your compression or camshaft.
If you are running a rapid lift solid lifter camshaft you must be careful how you adjust your lash. Most of these rapid lift cams run .012 to .014 lash(very tight). You can not allow much more lash than the manufacturer has on the cam spec card. If you do the valve train will accelerate so fast that you will get broken valve train parts. Surprisingly you can run considerably less lash. Hope this is informative and gives some insight.
Jim Lerum
[Edited by JLerum (09-24-2001 at 07:11 AM).]
[Edited by JLerum (09-24-2001 at 07:12 AM).]
1970 LS-6 Chevelle
Old 09-24-2001, 01:56 PM
I don't think this will help you any more, but for those curious, here is the CAM CARD for the L-71/L-72/L-78/LS-6 . Also, here is a CAM CHART with some more info on this cam.
[Edited by Chevy454 (09-24-2001 at 08:56 AM).]
