Old 07-26-2016, 01:49 AM
kwhizz kwhizz is offline
Default Re: Keith's 65
Getting closer........But........I found more "Dirt" !!!........Sheesh.......Does it ever end...In these "B" body LS swap's......the rear trans cross member needs to get moved back 2 1/4".....so.....I cut the frame mounts out and will re-weld them in position as required upon install..........Got the engine mounts installed and also the engine and transmission harnesses........Next......Get the drivetrain in the Car......Here are some Pic's
The Radiator showed up also
Old 07-26-2016, 02:00 AM
Plug and Play [img]<<GRAEMLIN_URL>>/headbang.gif[/img]
Old 07-26-2016, 03:13 AM
KM265S KM265S is offline
WOW, I did not realize my car was that DIRTY. I'm going to end up with some kind of a DIRT complex now and probably have to seek professional help. Sorry for making the mess in your garage. It looks &quot;GOODER&quot; everyday.
Old 07-26-2016, 01:15 PM
Default Re: Keith's 65 Impala upgrade
More new parts for your car are showing up @ Kens door everyday.
kwhizz (11-14-2024)
Old 07-26-2016, 10:14 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Mr70</div><div class="ubbcode-body">More new parts for your car are showing up @ Kens door everyday. </div></div>
Wow !!!!
Old 07-26-2016, 11:58 PM
ORIGLS6 ORIGLS6 is offline
That's the smallest tool box I've ever seen. [img]<<GRAEMLIN_URL>>/naughty.gif[/img]
Old 07-28-2016, 12:19 AM
Moved a couple steps forward today........Got the trans cross member frame mounts cut off the frame and the frame cleaned up and ready for welding them in their new position.....and Dave and Gary stopped over to help get the engine in the car.........Got it in and installed the trans cross member , then got everything in position and Brent was there to weld the frame mounts in their new position......started to separate out all the wires and got the Headers installed........Moving along..........
Old 07-28-2016, 12:31 AM
You could of at least loaned him the yellow Impala while you have his apart....... [img]<<GRAEMLIN_URL>>/haha.gif[/img]
Old 07-28-2016, 12:56 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Charley Lillard</div><div class="ubbcode-body">You could of at least loaned him the yellow Impala while you have his apart....... [img]<<GRAEMLIN_URL>>/haha.gif[/img] </div></div>
Just remember...........This is all your fault !!!!!!!
Old 07-28-2016, 12:44 AM
The LS Garage and Crew [img]<<GRAEMLIN_URL>>/youguysrock.gif[/img]
