Old 03-13-2009, 12:10 AM
JoeG JoeG is offline
Default Re: Low oil pressure in ZL-1
****Not saying it is,*****but I had a similar problem years ago on a rebuild--low oil pressure --oil pressure would increase some if I brought up the rpms..but would drop very low once the rpms came down----------We wound up changing the defective cam bearings,,,,Note: this is a last resort..The bright side of this problem is that you caught it in time,......
Old 03-13-2009, 12:26 AM
69SSZL1's Avatar
69SSZL1 69SSZL1 is offline
You did put the relief valve in pointing the right way?
1968 Z/28 34,000 mile, born with engine and trans, Shipper, California car, Fathom Blue, deluxe interior, M21, 3.55 Posi
1962 Oldsmobile Jetfire, Factory all Aluminum V8 Turbocharged and Methanol Injected TURBO ROCKET engine, 4 speed Hydramatic, 4 link rear suspension, 3.36 Anti-Spin differential, California car, PS, PB, PW, AC, Jetfire 2 option package.
Old 03-13-2009, 12:34 AM
69SSZL1's Avatar
Yes, wrong or loose cam bearings could do it. My machinist said the ZL-1 cam bearings were not standard BBC, he put in Dart Block bearings-Durabond HP cam bearings GMP-12. Just throwing things out there.
Old 03-13-2009, 12:39 AM
Alss's Avatar
Alss Alss is offline
OK which is the right way??..looked to be only one way but ......
also noticed when we were running the oil pump with a drill it never seemed to load up when it caught prime..Usually they really need some power to turn..this one never seems to prime and load the drill..maybe bad oil pump??
1969 Beaumont 540 th400 3.70
1968 Camaro ragtop LSA ZL1
Old 03-13-2009, 12:40 AM
Alss's Avatar
aware of the different cam bearings for this block..did buy the right one..but..we are going to re-check everything now..gonna pull some caps and make sure all is well
Old 03-13-2009, 03:53 AM
HPMIKE HPMIKE is offline
Yes.
As stated previously,especially with cold oil the drill should kick back on you. If you aren't feeling that there there obviously is a problem. One thing you can do listen carefully because sometimes you will hear a gurgling or dripping sound where the oil pressure is being bled off. Are you running a roller cam in this motor? What type of lifter are you running??
If you would like to PM me I can carry you through this a little further. You also are more than welcome to call me at my shop (973)-267-4364.
MB
Old 03-13-2009, 04:10 AM
Alss's Avatar
MB
thanks Mike..running a Liunati solid roller..either comp or redline/redzone/redsomething roller lifters..nothing new or exotic..really has me scratching my head..12 hrs till engine removal
Old 03-13-2009, 04:25 AM
92646 92646 is offline
Leave the motor in. Load the car on a Reliable truck to southern California and I will send you a check or wire the money to you. Then you can build another restored car and we can all watch the pictures again.
Mark Sheppard
Old 03-13-2009, 05:12 AM
Joe69Camaro Joe69Camaro is offline
BTW... Since you have so much to say, the machinist did my motor as well. And runs like a raped APE... By the way, do you have any el-camino parts for sale ????? Or other parts???
Tubbed 69 camaro
Old 03-13-2009, 05:37 AM
NO COMMENT 427 SILICONE KING
Tubbed 69 camaro
