Old 09-04-2019, 10:42 PM
Enoch Enoch is offline
Banned
Excellent survivor distributor hold down bracket and RBW head marking bolt. Perfect for any survivor engine compartment. $20 PP FF
Old 09-04-2019, 10:45 PM
Banned
Four bolt main 396 427 454 oil passage plug with W stamping on it. The two outer plugs in the pictures have the W underlined. The center plug is in NOS piece.
$30 each PP FF.
This is the fitting that goes next to the brass fitting on four bolt main blocks.
Old 09-04-2019, 10:48 PM
Banned
Original translucent Danco stamped rear end vents. The repros have a green cap to them. These both are in very nice condition. $15 each. Ppff (X)
Old 09-04-2019, 10:55 PM
Banned
68 through 72 small block steel valve cover rubber grommets. Including 68 Z28 and l79 and all 69 up steel valve covers. The angled valve cover grommet has a concentric ring around it and GF embossed on it. The other valve cover grommet has a concentric ring on the top and AB 131 embossed on the bottom with mold release marks. Excellent original pieces. $35 for the pair ppff.
Old 09-04-2019, 10:57 PM
Banned
One year only 69 vented power steering cap in excellent condition. $20 ppff (x) ************SOLD************
Old 09-04-2019, 11:01 PM
Banned
Excellent original restored High Performance Small Block crankshaft balancer mounting bolts with safety wire hole. TR head marking. External toothed star washers have the flat ends not pointed. Very nice original pieces. $45 each. Ppff (X)
Old 09-04-2019, 11:06 PM
Banned
I just got a couple sets back from the plater of the NOS WITTEK # 10 big block bypass hose clamps. These have never been reproduce correctly. $20 a set shipped to the lower 48 ppff
Old 09-04-2019, 11:09 PM
Banned
Exceptionally nice s stamped plates dial distributor hold down clamp and SB head marking bolt. $25. Ppff (X)
Old 09-04-2019, 11:13 PM
Banned
Excellent restored smog pump pulley bracket bolts with RBW head marking and diverter valve mounting bolts with RSC head marking. As nice as you're going to find. $35. PP FF (x)
Old 09-04-2019, 11:16 PM
Banned
Exceptionally nice three-quarter inch heater hose to water pump fitting, long style with notches on corners of each hex. As nice as you'll see. $30. This is correct for short water pump style Motors. Both small and big block.
