Old 04-04-2006, 06:22 AM
WILMASBOYL78's Avatar
Default Re: Winter/Spring project..
The little black Nova is making more progress tomorrow. Taking it over to a local buddies shop to install new front springs and control arm bushings. We will also freshen up the brakes and try to fit some headers to the existing exhaust.....Hey Sammy!!....found an old driveline loop at the shop, thought I might throw it on for good measure. Should bring it back home by the weekend and then start on some new valve springs and timing chain. Radiator is being serviced, rebuilding w/pump, starter, alt., etc. Then 163/850 setup goes on. Hope to have it running by the 15th...stayed tuned to the L78 channel.
wilma
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
Old 04-09-2006, 11:51 PM
Update on "the project"...front end is completely apart. Took all the control arms, brake spindles, backing plates, etc. to my local NAPA guy who has a hot tank and media blaster. Everything will be cleaned and all new bushings and lower ball joints installed. Removed original engine harness today (what was left of it). New unit going in this week. Cleaned the rest of the steering components and got some of the 35 year old grime off steering box. Original BB coil springs still had their tags: HH 3955727 Steering box had 5679142 dated 209 & HP stamped in yellow letters???? Cover of steering box had 7802287 CBC 13. All the tie rods and othe stuff appears to be original..very little wear. More parts to blast and clean this week and then hopefully get the front end back together by next weekend. Stay tuned..
wilma
02 Berger 380hp #95
Lots of L78 Novas
70 Orange Cooler
69 Camaro
Old 04-10-2006, 01:04 AM
bbbenny bbbenny is offline
wilma, it sounds like your going a full day two project!!!!! where;s sammy when you need him? check with vera!!!!bbbenny
Thanks Benny
Enjoy; orginal cars,with orginal drivetrains and docs. bblocks are my favorite.
Old 04-10-2006, 01:18 AM
wilma
Hey Wilma, you mentioned a date of "209" on your steering box. How is that interpreted?
Thanks,
Sam
Old 04-10-2006, 02:09 AM
here is some additional info from the steering box. I checked some detailed photos from one of the other cars. there is a little date tag that extends off the side of the aluminun cover. My May 1969 car has a date of B 1209..not sure what the B stands for, but 120th day of 69 is the rest. The little tag on the 70 car has B 0130...13th day of 1970..car has a January 21st build date. So the unit is original to the car. I also found the number 14 above the 290 on the housing...on the 69 car there is a 9 in that spot with same casting #. I think the 290 refers to the 290th day of 1970 model year, which would be approx the end of Sept. 69. I would assume the housing would be cast prior to the assembly date of the component. These little things are neat..if anyone has additional info on deciphering i would appreciate it.
wilma
02 Berger 380hp #95
Lots of L78 Novas
70 Orange Cooler
69 Camaro
Old 04-17-2006, 08:18 AM
The project continues...got all my control arms back yesterday from the shop. Clean and nice...all parts got primed and painted today for reassembly. There are a lot of parts in a Nova I cleaned and painted all day!! Just stopped long enough to look at what I got in my Easter basket The final assembly will have to wait until after Carlisle...hope to see some of you boys at the fair.
wilma
02 Berger 380hp #95
Lots of L78 Novas
70 Orange Cooler
69 Camaro
Old 05-15-2006, 05:09 AM
It has been awhile since the last update on the project car. Here is the latest report; found some great 15' steel wheels(with the help of Sammy) got them cleaned and painted today, 1st coat...GTO Don helped out with some vintage rubber that will go on those steel wheels: Goodyear polyglass F-70x15 fronts and H70x15 rear..should look awesome!! Still cleaning and painting lots of small parts but that stuff is pretty much done as of today. Rebuilt alternator and starter so there won't be any hassles. Found a date code correct 2000 distributor in my "parts pile" and got that spruced up and ready for action. Hope to finish engine related items this week and then concentrate on finishing suspension. 4.56 posi rear will get some fresh oil and lube along with the cool Day 2 finned cover...too many parts and too little time!
wilma
02 Berger 380hp #95
Lots of L78 Novas
70 Orange Cooler
69 Camaro
Old 05-15-2006, 06:24 AM
Sounds like you are right on target Tommy!
Old 05-24-2006, 07:57 AM
Sammy, more progress on the project....restored control arms are in. Rear brakes are all set and ready to go. Got the GTO Don tires mounted on some stock Chevy steel wheels and they look awesome! We put in the new Eaton coil spring in the drivers side tonite....what a job these springs are 1" taller than stock..the spring compressor was working overtime! we will finish pass. side tomorrow nite and then get her back on the ground. Hope to take some photos this weekend when Benny is here. Thanks for the time....
wilma
02 Berger 380hp #95
Lots of L78 Novas
70 Orange Cooler
69 Camaro
Old 06-14-2006, 07:30 AM
finally some lousy photos...
wilma
02 Berger 380hp #95
Lots of L78 Novas
70 Orange Cooler
69 Camaro
