Old 07-24-2015, 09:25 PM
Ryan1969Chevelle's Avatar
Default Re: Ryan Weaver's 1969 Olds Cutlass S W31 Club Coupe
So I will keep looking for one
Ryan
Old 07-24-2015, 11:14 PM
Stefano Stefano is offline
Yes Ram Rods and W-31s had fan shrouds.
Old 07-25-2015, 12:30 AM
Stefano, could I bother you for a part number?
I don't want a new part, as I have seen you can still buy these from GM, but a modern part:-(
Ryan
Old 07-25-2015, 02:51 AM
Not sure w/ '69 W31's but besides HD cooling, some rear axle ratios dictated whether shrouds were included w/ other 68-72 A-bodies.
Destined for Canada or CA may make a difference too but what axle is your car Ryan also is the ratio of the one Stefano posted known?
[img]<<GRAEMLIN_URL>>/hmmm.gif[/img]
Old 07-25-2015, 03:04 AM
Mine has 3.42, I think Stefano's is 3.91
V02, vs V01 Radiator
Ryan
Old 07-25-2015, 03:53 PM
83hurstguy 83hurstguy is offline
Ton of info (and arguments) about shrouds here: http://classicoldsmobile.com/forums/...n-shrouds.html
Post 13 starts a discussion on '69 W-cars. The PIM appears to say &quot;no&quot; for an OAI car with manual trans, other people are saying &quot;yes they got them&quot;.
If you are planning on street driving this thing, I would put the shroud on it. Points for correctness don't matter when you are puking antifreeze everywhere on the side of the road. [img]<<GRAEMLIN_URL>>/smile.gif[/img]
Dave H does not have a shroud on his original owner '68 Ram Rod. I just double checked my MCACN pictures to be sure.
One other side note, Stefano, the shroud on that Ram Rod is a '69-up piece due to the square bump for the hose strap (that's not there), so it's very likely not original to the car. '68 used a one year only shroud, the upper hose straps directly to the top core support instead of the plastic shroud in both small block and big block cars.
'68 H/O W45
'70 Cuda
Old 07-25-2015, 04:00 PM
Thanks Luke, I will definitely be using a shroud!! After a 41 year sleep this W-31 will be driven, she needs to be reliable!
Do you know the part number, or have pics of what to look for?
Ryan
Old 07-25-2015, 06:25 PM
No prob. 402995 (more details in that thread). They were still available NOS a few months ago, or a wanted ad on classicolds should get you more of an original/patina nice one if you are going for the unrestored look. Should be easy to get one.
There's a generic HD Delco fan clutch for later Olds 307 that should bolt on and keep it cool as well if your original is toast. I don't have the p/n handy at the moment... It's not a perfect original, but with a shroud, you can't see the clutch anyways... My 68 has the original OS clutch in good shape, I may switch to the new HD one so it stays cool. Haven't decided yet...
'68 H/O W45
'70 Cuda
Old 07-26-2015, 01:12 AM
Great stuff!!
I will find one!! (Shroud)
How do you test the clutch fan?
Ryan
Old 07-26-2015, 03:41 AM
The most obvious issue would be leaking fluid. Other than that, you can try to spin the fan with the clutch stationary, and the fan should &quot;drag&quot; and not spin more than 1/4-1/2 revolution. If it freewheels, it won't be spinning under load. Of course, the final test is keeping the car cool at idle. You should be able to give it a quick spin test without worrying about ruining the &quot;barn find&quot; patina for MCACN. [img]<<GRAEMLIN_URL>>/smile.gif[/img]
The AC Delco HD clutch is 15-40108, found it. If your clutch is good, I'd be inclined to run it, use this number as a backup or if it wants to run hot at idle.
'68 H/O W45
'70 Cuda
