Old 02-14-2009, 11:16 PM
Default Re: really cool 70 Z28..simply the best.
I believe the paint marks were applied after the hood hinges were properly adjusted.
Paul
Old 02-14-2009, 11:44 PM
x  Baldwin  Motion's Avatar
Charlie, you didn't have to drop the gas tank ? Was it bone dry?
Great to hear it run. I quickly got off the lap top and went to surround sound
Old 02-15-2009, 12:53 AM
budnate's Avatar
budnate budnate is offline
I am on a old laptop on vac...what video format changed at youtube?? ....Dang thing wont play just pops up a black screen........HELP
Old 02-15-2009, 02:09 AM
Very, very Charley Your picture and video posting efforts are not unappreciated
Bill Pritchard
Old 02-15-2009, 02:26 AM
GaryH GaryH is offline
Charlie, how about a quick run down on what you did in preparation for the fire up. Did you pull the distributor and prime the pump? Drain the tank, change the oil etc.?
Gary
71 LT-1 Vette
85 IROC (Modified)
09 SRT8 Challenger 6sp Kenne Bell on the way
Old 02-15-2009, 03:35 AM
click....drives
Old 02-15-2009, 03:55 AM
Gary. I had pulled the plugs, squirted motor oil in each cylinder and let it sit for a couple days, turned with torque wrench on the crank and tapped the starter. The dist will not com out so there was no way to prime it that way. Squirted more oil in cylinders and cranked it over with the plugs out. Oil pressure light went out right away. Put 3 gallons of race gas in the tank. Had to file the points to get spark, pour gas in the carb to make it fire. When it fired yesterday there was gas leaking out of the carb from shrunken gaskets.
Old 02-15-2009, 03:56 AM
Old 02-15-2009, 03:57 AM
When I pulled the float bowls off they were absolutely clean inside. Whole carb was clean. Just shrunken gaskets.
Old 02-15-2009, 03:59 AM
