Old 05-16-2017, 05:16 PM
VintageMusclecar's Avatar
RXT clutch is in. All the gory details of the install are on my FB page.
Test drive report soon.
Old 05-16-2017, 07:19 PM
Best wishes Eric!!
VintageMusclecar (05-16-2017)
  #713
Old 05-18-2017, 10:00 PM
The first test drive is in the bag--just a brief jaunt around the neighborhood, stayed close to home "just in case", but so far, so good.
The pedal effort is very comfortable, and as far as "driveability", I can already state that this is by far the most street-friendly clutch I've had in the car so far. Zero chatter, even in reverse, very easy to--for lack of better term--ride, not like the previous race clutches which were (to varying degrees) more like an "on/off' switch.
I didn't lean on it at all, so as far as holding power goes, the verdict's still out on that. However, should this clutch perform as advertised, I will officially consider myself a McLeod convert.
More soon--weather permitting.
Old 05-18-2017, 10:16 PM
earntaz earntaz is offline
Keep your fingers crossed Eric -- sounds like you finally hit the right combination ... Craig
Old 05-18-2017, 10:49 PM
Sounds awesome Eric. I hope it will handle the power.
Jason
Old 06-30-2017, 03:35 PM
Clutch update:
It holds.
Old 06-30-2017, 09:36 PM
Yee haw!!!
Old 06-30-2017, 10:57 PM
njsteve njsteve is offline
Congratulations!
Old 06-30-2017, 11:55 PM
This clutch definitely hits harder than its predecessors.
Gonn'a have to watch it pounding it on the shifts--that poor 12 bolt's already hacked out parts once.
Old 08-24-2017, 11:46 PM
Pretty sure the Legend trans in the Chevelle is on it's way out. It's making some very unhappy noises and there's a new driveline vibration that definitely isn't engine related. Not sure where I'm going to go from here.
