Old 02-15-2009, 10:46 PM
Default Re: really cool 70 Z28..simply the best.
Also looks like silver paint on head next to intake bolt. Other areas are too hard to tell or bare.
Old 02-15-2009, 11:07 PM
Steve Shauger's Avatar
Administrator
My understanding is that area was painted with aluminum/silver paint to cover bare metal between head and intake. This also why the intake bolts,engine lift brackets and distributor hold down had aluminum overspray. I believe this is why the wirestands were touched up by brush (due to silver overspray). These are the areas/details jewels of information that can only be found on true survivors.
Any overspray on the valve covers??
www.yenko.net
www.vintagecertification.com
Old 02-16-2009, 01:02 AM
Apparently the the drivers wire shield brackets were installed before the engine was painted... the pass were one piece and installed afterwards. It may have to do with how the manifolds are shaped... mid exit on drivers vs rear on the pass.
It looks like the silver was sprayed in order to protect the bolt heads from flash rusting.
Old 02-16-2009, 01:50 AM
m22mike's Avatar
m22mike m22mike is offline
Also a great shot of the trunk spatter detail. This one seems to be a more stringy one, as compared to the round blobs.
Mike
Old 02-16-2009, 01:54 AM
SIMPLY AWESOME!... Are you going to be taking it to the Camaro Nats in June?
Old 02-16-2009, 03:01 AM
Probably not. Too much to ship it back and forth. I will probably attempt to have it at whatever show Ashton puts on in Chicago in November. I can then get Norman and his brothers there with the car also.
Old 02-16-2009, 03:32 AM
KENNY_PASCOE KENNY_PASCOE is offline
GREAT TRUNK SHOT. FROM WHAT I HAVE SEEN ON LA CARS THE TRUNK SPATTER IS STRINGY COMPARED TO THE NORWOOD CARS. KP
1969 CAMARO SS 396/375 VAN T SOLD
1966 CHEVELLE SS 396/375
1969 CAMARO Z/28 ORIGINAL PAINT
Old 02-16-2009, 07:03 PM
TimG TimG is offline
I'm lovin this, thanks for the shots, Charley.
Old 02-16-2009, 09:00 PM
L72COPO L72COPO is offline
Darren did it.
Don Stowers
66 GTO, Tri power, Fact. A/C, 4 speed
65 Corvette, L-76, Conv., Fact. A/C
63 Corvette SWC
Old 02-16-2009, 11:00 PM
Hotrodpaul Hotrodpaul is online now
Charley, when you get a chance, could you update the hood and trunk stripe dimensions called out in the 1970 Camaro Assembly manual on sheets B2 and B3 of the Z28 option code using your car for reference, then post them for all to see? The dimensions shown are for Norwood built cars. Thanks,
Paul
