Old 02-17-2009, 11:12 PM
Jacsey 70Z Jacsey 70Z is offline
Default Re: really cool 70 Z28..simply the best.
Charlie, If you remove the bottom two bolts the shocks will extend far enough to read the dates (Thats what I did)understand if you don't even want to go that far.
Jack Seymour
1970 Z28
Hugger Orange
20K Mile Survivor
Old 02-18-2009, 12:34 AM
ORIGLS6 ORIGLS6 is offline
I will have to look. It might be buried in undercoat.
The one and only black printed filter I've seen had only the AC logo, "Full Flow" to the left and "Type PF 25" to the right. No stripes above and below and none of this text on the reverse side.
"THE EFFICIENCY AND CAPACITY OF THIS NEW
OIL FILTER WITH ACRON FILTERING MATERIAL
AND UNIQUE “W” FOLD EXCEEDS THAT OF THE
LONGER PF-11 OR PF-29 IT REPLACES
TIGHTEN ONE TURN AFTER CONTACTING GASKET
CHECK FOR LEAKS"
I was told by a reliable source (who you know) that it was on an extremely low-mile L78 engine from a '70 Camaro. I've seen the filter and am convinced it's legit.
Old 02-18-2009, 02:27 AM
John Brown's Avatar
CHECK FOR LEAKS"
Do you mean none of this ?
John Brown
chevjon396 chevjon396 is offline
Charlie,
This is great car. Super nice details. could you get a detailed picture of the carb return spring. Thank you.
John Haislip
70 Z28
Mulzane Blue
Bright Blue interior
25K survivor
Old 02-18-2009, 04:22 AM
"Do you mean none of this ? "
Yep. The only print on the filter is the round AC logo, "Full Flow" to the left and "TYPE PF-25" on the right. And all the print is in Black.
Old 02-18-2009, 05:06 AM
carb spring
Old 02-18-2009, 05:08 AM
what you can see of the filter
Old 02-18-2009, 05:09 AM
Old 02-18-2009, 05:10 AM
Old 02-18-2009, 05:19 AM
Notice the stuff that oozed out from between the trunk and hinge.
