#71
I have used hundreads of Jeff's distributors, and have even done some articles on them years ago, They are a good piece, I like to run the upper o ring and not the lower and I also like to cut a .010 groove in the lower to give the cam gear a little extra oiling on roller cams. Also use assembly lube on new gears icluding cam gear and distributor gear.
Did your verify that the 3 1/8" pipe plugs are installed in the lifter valley oil gallery? they look like bolt holes but go right into the gallery and without them the oil will just squirt into the lifter area. The distributor does not need any o-rings, any standard Chevy distributor will work.
1968 Z/28 34,000 mile, born with engine and trans, Shipper, California car, Fathom Blue, deluxe interior, M21, 3.55 Posi 1962 Oldsmobile Jetfire, Factory all Aluminum V8 Turbocharged and Methanol Injected TURBO ROCKET engine, 4 speed Hydramatic, 4 link rear suspension, 3.36 Anti-Spin differential, California car, PS, PB, PW, AC, Jetfire 2 option package. |
#73
double check the lower o-ring situation
what camshaft? what year block? also, is it a roller cam? if so are the lifters correct? if not, they could hemmorage oil by uncovering the galley/lifter bore and it bleeds towards the pan area.. if rod side clearance is more than .010/.012 it'll lose it there also are you taking pressure readings at the oil filter pad or the rear upper port behind the intake?
aka - Mighty Mouse |
#74
Did your verify that the 3 1/8" pipe plugs are installed in the lifter valley oil gallery? they look like bolt holes but go right into the gallery and without them the oil will just squirt into the lifter area. [/ QUOTE ] we have a winner!!..you guys are good..just a little late..Jking ![]() question on 074 heads..exhaust crossover..wet or dry..I have some water in mine..from the dissassmbly poosibily? thanks again everyone for your knowledge and support Albert
1969 9566AA COPO Chevelle M-22 1969 Malibu 489 ZL-1 T-56/4.56 1969 Beaumont 540 th400 3.70 1969 Chevelle 300 Deluxe 427 ZL-1 M 22W 1970 Olds 442 W 30 2 door post 1969 Ply. GTX 426 hemi auto. Blue. 1940 Dodge pick up Durango 4X4 1968 Camaro ragtop LSA ZL1 |
#75
Probably a good thing those were missing or you may have never found out about the missing bypass valve? Congrats, ALbert! I wish I could have been more helpful.
Jason Jason |
#76
Is your engine assembly expert smacking himself on the forehead and doing a Homer Simpson "Doh" ?
#77
Is your engine assembly expert smacking himself on the forehead and doing a Homer Simpson "Doh" ? [/ QUOTE ] over and over again!..we have to have a little talk ![]()
#78
Is your engine assembly expert smacking himself on the forehead and doing a Homer Simpson "Doh" ? [/ QUOTE ] ![]() |
#79
[b] Happy endings are always enjoyable!!
A Homer Simpson "Woo Hoo!" and sound of beer can opening
