Old 02-15-2022, 08:45 PM
L78_Nova's Avatar
L78_Nova L78_Nova is online now
While the rear portion of this LH trunk drop was a little better than the RH was;
The front portion was a little worse;
This patch was a little more challenging. I was able to find a piece in my scrap pile with a portion of the round raised shape to begin from. Drilled and slotted it out to match the plug then welded it in to the piece of replacement flange (similar to RH side).
Quite a bit of cutting welding and grinding for such a small patch but I wanted to copy the original shape as closely as possible. I was happy with the result. finished from the underside you cannot tell from factory.
70 Chevelle SS-454 LS-5 M-22
big gear head (02-15-2022), markinnaples (03-08-2022)
Old 02-16-2022, 02:22 PM
L78_Nova's Avatar
Lower rear corner of LH inner wheel tub required a patch. Concave shape required several slices along the flanges to "participate".
Name:  wheel Tub 001.jpg
Fabbed and fitting... Faux spot weld dimples between plug welds
Blurry shot of welded in. Edge cuts remain to be welded.
Name:  wheel Tub 002.jpg
Crush (02-16-2022), olredalert (02-16-2022)
Old 02-16-2022, 02:44 PM
Great step by step pictures. Well done!
The Following User Says Thank You to Salvatore For This Useful Post:
L78_Nova (02-16-2022)
Old 02-16-2022, 03:14 PM
L78_Nova's Avatar
Lots of cleanup of the inner panels. Mostly wire wheel on a drill. Slow, tedious work but it really works well for the irregular shapes. Respirator and eye protection mandatory to avoid the orange cloud.
At this point the panel has been rough fit many times and the outer tub is now in place.
You can see the trunk floor and part of the hinge flange has also been stripped to bare while the quarter was off. Many hours climbing around in the trunk.
Everything clean and bare steel will get a heavy coat of DP90 epoxy. Surfaces like the sail panel which still have some surface rust will get POR15
big gear head (02-16-2022), Dave Rifkin (02-16-2022)
Old 02-16-2022, 03:49 PM
L78_Nova's Avatar
Installed the inner jamb reinforcement. Unlike the RH side there was no damage here so the plate was easy to correctly locate and weld in prior to the panel. Drilled for plug welds upon installation.
Sectioned in the lower half of the telephone receiver and removed the formed dimple in the jamb (per RH panel). Drilled for plug welds.
Inside view. Note lower corner of door jamb (RH side in picture). This area was a little mis-formed. The leading edge of the panel at the lower door jamb flared back a little leaving an awkward gap at the bottom corner. The contour of the paned was also slightly off at the lower leading edge. It was split, reshaped and welded up from the inside (built up to fill gap) to align correctly.
Old 02-16-2022, 07:31 PM
L78_Nova's Avatar
Prepping everything for the panel install. Sail panel.
If you look closely you can see the small faux spot weld dimples along the forward (drip rail) edge of the sail panel. The small reinforcement piece is welded in the corner of the quarter window. The faux spot weld dimples are in place along the wheel lip (foregound).
Everything is sealed with primer and scuffed where trunk spatter will apply.
The green tape is a small dam on the metal bracket to assist in catching the fusor foam which is later sprayed onto that ledge to dampen vibration to the sail panel. A lump of foam sandwiches between the inner and outer panel along that ledge.
Old 02-16-2022, 08:57 PM
Pro Stock John's Avatar
Do you have a background in body work or fabrication? I'd love to learn how to do my own stuff, I guess I'd first need to learn how to weld.
The Following User Says Thank You to Pro Stock John For This Useful Post:
Old 02-16-2022, 10:26 PM
L78_Nova's Avatar
Nothing formal...
Caught the car bug early from Uncle Norm that was a little car crazy; 69 Roadrunner 383, 67 Camino 396 4spd, 55 chevy P/U hot rodded. Then a couple older cousin's with a 66 Fairlane, 66 Beaumont, 67 Beaumont, 71 Cutlass 455.
In high school a good friend picked up a 70 Malibu which we pop riveted patches on and started slinging bondo. Shortly after another friend Steve, was in formal auto body trade school and we were soon hacking on stuff in his garage. He taught me quite a bit.
A friend's friend was the auto tech teacher for a small town High School. He offered to put on a one evening a week "school" for about six of us at the school's auto shop. We did about 10 nights each winter for two years. Essentially we just brought in our projects for the night and he guided us along on how to do it. Around the same time a towing buddy (with a Mig welder) helped me put floor pans in my 78 pick-up. For the "school" I put quarter skins on it and hung new doors on it. Then Steve painted it at his work. The second winter at "school" I did a complete repaint on my Dad's ford shortbox truck.
My 78 Shortbox in it's 80's glory. We don't need no steenking alignment !!
Name:  78 chevy.jpg
Somewhere along the way I stared at this article for waaaaaayy too long....
So... when I snapped an axle powershifting to second and lost a tire resulting in some quarter damage....
I went out to the garage and cut the inner tubs out of the car with a cold chisel and a 5lb sledge hammer.
Name:  72 Nova 03.jpg
It was game on after that. I've had a lot of help from friend's in industry along the way
The Following 3 Users Say Thank You to L78_Nova For This Useful Post:
markinnaples (02-17-2022), Too Many Projects (02-16-2022), Xplantdad (02-16-2022)
Old 02-16-2022, 11:17 PM
Originally Posted by L78_Nova View Post
Nothing formal...
Attachment 214049
Attachment 214052
Attachment 214053
Attachment 214051
That magazine Nova, Dreamweaver- looks a lot like this one I took at the street machine nationals in the early 80's in Pomona, Ca
Another of my favorite Novas...with a dana 60!
The Following 2 Users Say Thank You to Xplantdad For This Useful Post:
L78_Nova (02-16-2022), markinnaples (02-17-2022)
Old 02-17-2022, 04:25 AM
SPEEDYB SPEEDYB is offline
Bruce, thats the car for sure, I'll never forget that big block w/ gold moroso valve covers and matching Dana cover.
A street racer among fairground pro street cars, stared at it for hours!
The Following 2 Users Say Thank You to SPEEDYB For This Useful Post:
L78_Nova (02-17-2022), Xplantdad (02-17-2022)
