Old 09-14-2013, 11:50 PM
njsteve njsteve is offline
Default Re: The New, Newer Project Part Tres...
Thank you for the compliment. Just trying to have fun. [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 09-14-2013, 11:59 PM
I took the white car over to my buddy's garage today to get some underside shots. I took around 140 photos of just about everything. Lots of neat stuff under there that I have never seen before on a second gen car. The camera didn't have a wide enough angle lens so I had to shoot the car down the center, then down the sides to get all the details. So here goes:
Old 09-15-2013, 12:09 AM
The right side. Note how little paint got on the lower portion of the rocker panels on the passenger side. The driver's side rocker bottom got a lot better coverage. Must have been a shorter painter on the left side of the paint booth that day.
Old 09-15-2013, 12:15 AM
And the driver's side:
Old 09-15-2013, 12:20 AM
Here's something interesting. I have never seen this bracket on the cross member the purpose of which is to retain the speedometer cable.
This clip is on the driver's side inner frame rail:
This bracket is on the driver's side inner frame rail below the steering column:
Old 09-15-2013, 12:48 AM
French locks on the exhaust manifold bolt:
Matching VIN on Turbo 400 transmission:
Unpainted, galvanized floor plug
Emergency brake adjuster with single, nylock lock not.
GM stenciled fuel lines on subframe with color coded spring clamps:
Fuel pump part number:
&quot;FU&quot; paper tag on front sway bar:
Driveshaft color coded paint stripes:
Limited Slip metal tag in factory installed position at bottom:
Orange painted &quot;G&quot; on the bottom of the differential. The differential center section appears to be natural cast iron, with the tubes and mounting plates painted black.
&quot;LS2&quot; on the underside of the radiator support, denoting the SD455 option:
Yellow crayon &quot;53 H&quot; on the inside of the passenger side subframe rail:
Original spiral shocks all around. The car rides very nicely on them. You can see the black painted rear differential base plates:
Old 09-15-2013, 01:07 AM
And here's a comical one: Nice build quality/alignment on the rocker panel installation. [img]<<GRAEMLIN_URL>>/rolleyes.gif[/img] It is sticking out about a 1/4&quot; from the bottom of the quarter panel. The passenger side is flush with the quarter.
Old 09-15-2013, 02:38 AM
67 442 67 442 is offline
Has the exhaust system been replaced?
Old 09-15-2013, 03:23 AM
No, that is the original exhaust system, including muffler. The SD455s had a unique system made of multiple tubes that were welded together to make the long sections.
Old 09-15-2013, 07:31 PM
Started tinkering yesterday. The original master cylinder was leaking badly at the rear seal by the booster. Brake fluid was running down onto the subframe. Luckily I still had the reproduction master cylinder left over from the black 72. So I installed that one as a stuntman for the original one while I send this one out to Whitepost.
From sitting for 40 years with the same brake fluid, the bottom of the reservoir was filled to about 1/4 inch with rusty colored goo. It was a bear to get the inner far piston out. That same rusty goo was in the bore area as well and not only pitted the bore but devoured the valve itself:
You can see that these master cylinders were painted a flat black originally. Not a lot of the paint remains but it is there in places.
Here is the reproduction bleeder style master cylinder in place with the original cap and bail on it.
