Old 09-09-2019, 11:04 PM
Enoch Enoch is offline
Banned
Original assembly line installed white stripe vacuum hose. Also used for smog. 33 + 1/2" Long. $60
Old 09-09-2019, 11:14 PM
Banned
Original assembly line white stripe smog / vacuum hose. 21 in Long. $ 45
Old 09-09-2019, 11:19 PM
Banned
Exclamation
Original white stripe vacuum smog hose. 27 inches long. $50
Old 09-10-2019, 12:30 AM
Banned
Original 6.5' length of 68 and 69 Rally Sport Camaro intake manifold vacuum fitting to check valve, filter and reservoir tank hose. Excellent original assembly line piece 6 ribs. $45.
Old 09-10-2019, 12:58 AM
Banned
67-69 small block cross shaft. Original piece replated 25 years ago. $80 plus shipping.
Old 09-10-2019, 01:09 PM
Banned
Original clutch pedal to Z bar push rod. Remove from a 69 Camaro many years ago. $35. Replated.
Old 09-10-2019, 07:35 PM
Banned
2 original 4 bolt main big block weather head stamped brass oil line to block fittings. Not being reproduce with the original weather head stamping or original concentric machining marks on surface. $40 each PP FF
BUSHING ON THE LEFT IS ************ SOLD ************ (X)
Old 09-10-2019, 07:40 PM
Banned
Very nice 45 degree with pipe extension brass oil line to block fitting. Weather head stamp. Again not being reproduced correctly. $25 Ppff (X)
Old 09-10-2019, 07:43 PM
Banned
Original 2 bolt main big block low horsepower straight oil pressure line brass bushing to block. Very nice original piece. $25 PPFF (X)
Old 09-10-2019, 07:46 PM
Banned
Small and big block oil pressure line compression fittings. And bushing. Fitting on the left is NOS <CP> PAT PEND stamped. $30. I have 10 left. Fitting on the right has a weather head stamp on the lower bushing. Very very hard to find. $40. Ppff (X)
