Old 11-25-2023, 02:09 AM
hubleyman hubleyman is offline
1969 Chevelle SS 396 / 325 block.
I have a 1969 Chevelle SS 396 / 325 HP with 4 speed bare block and thought it would be good to post the data here in case the car still exists. Feel free to share this information anywhere that may be helpful to others.
It's a Fremont built car that is stamped 119z348164 and T0418JA. Casting 3955272 with date code C 27 9 for reference.
I believe this would be 136379Z348164 for a coupe and 136679Z348164 for a convertible?
Being a local (to me) built car, it may still be around here... The block is clean and mag'd good and is only .030 over bore (with some wear), so I'm not sure why it didn't stay with the car?
Charlie (aka: hubleyman)
The Following User Says Thank You to hubleyman For This Useful Post:
dykstra (11-25-2023)
  #152
Old 12-31-2023, 12:30 PM
67Ss4spd's Avatar
67Ss4spd 67Ss4spd is offline
Yenko Premier Member
• 1967 CAMARO 396 block in search of its original frame perches
3902406 - 2 bolt mains
Standard Bore, not decked
3-20-67 - Cast
T0413 MW - Assembly
7N209356 - VIN
possible trades -
Steve - [email protected] - 847-744-0084
Old 03-15-2024, 05:26 PM
Abiato
Guest
Posts: n/a
3-20-67 - Cast
T0413 MW - Assembly
7N209356 - VIN
possible trades -
Can you attach a photo?
Old 03-20-2024, 11:03 PM
67Ss4spd's Avatar
Default Pics
Attached
Steve
67 Chevelle SS
Old 03-21-2024, 04:22 AM
1crossram 1crossram is offline
Default Late 1966 M21 transmission Chevelle?
Hello, I have a complete together Muncie transmission that could be for a Chevelle. Looking to reunite it with the car if possible.
Main case #3885010
Date stamped P7T21
VIN #7K112719
Please contact if you have the vehicle. Transmission is out of a car on a dolly.
Thanks David
1967 Camaro RS/SS convertible Butternut yellow with black power top, factory AC
Rebuilding 1967 RS headlight motors
