As my diner story mentions in the lounge section...the 70 4spd car seems to have a gas gauge issue. It reads full...almost too full if you know what I mean.
That should of made me check things...but I figured there must be enough gas...wrong. ![]() I will add some fuel today to get her running... Any suggestions on how to scope this out..?? Electrical things are not my strong suit. -wilma
My experience has been, if it reads empty (and its not) then the sending wire is grounded. If it reads full or above the sending wire is open. Bad connection or broken wire. If you recently unplugged anything under the dash, look at those connections as well such as where the intermediate harness plugs into the dash harness.
Rick Nelson Musclecar Restoration and Design, Inc (retired) www.musclecarrestorationanddesign.com https://www.youtube.com/watch?v=62r-6vgk2_8 specialized in (only real) LS6 Chevelle restorations |
The Following 2 Users Say Thank You to SS427 For This Useful Post: | ||
Arrowsmith (09-23-2023), L_e_e (09-24-2023) |
When it reads full the fuel sender is resistor is open therefore infinite resistance so it reads full. Check the resistance of the sender directly first and if ok check the wiring from the sender to the guage.
Steve Shauger The Supercar Registry www.yenko.net Vintage Certification™ , Providing Recognition to Unrestored Muscle Cars. Website: www.vintagecertification.com |
The Following User Says Thank You to Steve Shauger For This Useful Post: | ||
Arrowsmith (09-23-2023) |
![]() Quote:
0 ohms Empty 90 ohms Full An Open or infinite resistance will drive the gage to the right way past full indication. Servicing sheet attached. I built a "Gage sender" simulator that can be temporary installed in place of the Gas tank sender to the Car wiring and drive the Gage while sitting in the drivers seat. The Same can be accomplished by using a Resistance Decade box, but this tool is plug and play. JIM
69 Los Z11 68 SS/RS 396/325 68 Los Z28 ![]() |
The Following 2 Users Say Thank You to 169indy For This Useful Post: | ||
Testing can also be accomplished shade-tree style with a known good gauge sender and jumper leads to the sender harness and ground, to either condemn or rule out the sender. Or, just ground the sender connection and see if it goes to empty.
I've found that the transmitting wire is grounded if it reads empty. The transmitting wire is open if full or higher. Misconnection or wirebreak. Check the intermediate harness-dash harness connections if you recently disconnected something beneath the dash.
Great savings on Blackpool Pleasure Discount Code |
