Old 04-20-2019, 12:17 PM
L_e_e's Avatar
L_e_e L_e_e is offline
In a 69 Dodge Charger with power windows, if you don’t have the keys on you and you need to close the windows, turn on the emergency flashers, step on the brake, set the turn signal lever in the left or right signal position, and the power windows will operate.
It works on GM's too, except you have to hold the emergency flasher half way in.
Old 04-20-2019, 01:01 PM
earntaz earntaz is offline
"A Charger Daytona has the exact same rear window glass as a Vega hatchback"
Is that quote correct?
Huh??
Old 04-20-2019, 01:05 PM
Originally Posted by StriperSS View Post
It was Montana, and it was called 'Reasonable and Prudent'. A friend got a ticket though, in his Viper, after people complained that he was driving too fast, on his way to Las Vegas!
Just remembered -- Texas a a few stretches that are good for 85 MPH ... one of these is just east of SA basically connecting I10 to I35 ...
Old 04-20-2019, 02:05 PM
Keith Seymore's Avatar
With the 1977 Chrysler, the left fender mounted turn indicator would light up when the gas pedal was floored. When reading the owner's manual the answer turns up. The car had a "gas saver" feature- upon low to no vacuum the fender light on the driver's side would light up, indicating poor fuel economy
Looks like John Delorean meeting with his attorney in the background on the steps...
K
'63 LeMans Convertible
'63 Grand Prix
'74 Chevelle - original owner, 9.85 @ 136 mph best
Old 04-21-2019, 04:35 AM
Old 04-21-2019, 05:42 PM
All year long as Earth revolves around the sun, it passes through streams of cosmic debris. The resulting meteor showers can light up night skies from dusk to dawn, and if you’re lucky you might be able to catch a glimpse.
The next shower you might be able to see is known as the Lyrids. Active between April 16 and 28, the show peaks around Sunday night into Monday morning, or April 21-22. The moon could interfere with viewing the peak this year.
Old 04-21-2019, 05:45 PM
Rare albino deer captured in photo by man driving through Michigan park
Old 04-21-2019, 05:49 PM
Most people live in a house like this. But some people . . . . . .
