Old 01-16-2020, 01:35 PM
bbbentley's Avatar
Good question Tim, as I have contemplated the same. The topic has me wanting to offer up a FB ad I could act on myself, but chose not to. There is a complete disc brake with 2 piece rotors and appears to be N44 arms on FB off a 69. What I saw right- steering box, all linkage, including idler arm that looked correct, 2 piece rotors, upper A arms, N44 ( pitman looked short and I did not ask for numbers). Has hard to come by clips on hoses to attach to A arms. Looks like original hoses, too. Wrong: calipers, upper ball joints replaced, everything a little crusty. PM and I’ll try and get you hooked up with seller.
FULL OWNER HISTORY
The Following User Says Thank You to bbbentley For This Useful Post:
ZLP955 (01-16-2020)
  #12
Old 01-16-2020, 02:45 PM
X66 714's Avatar
X66 714 X66 714 is offline
I got the cheap Rightstuff rotor assm. I just used the rotors & my original hubs. If you put 3 lug nuts on the studs it will give you 3 flat areas to put in the vise so you can torque the 5 attaching bolts to 65 foot pounds. Didn't think about balancing. We'll see what happens...Joe
Old 01-16-2020, 03:11 PM
m22mike's Avatar
m22mike m22mike is offline
Default HBC USA made rotor
Another consideration.
A few more $$, but this is a good quality USA made reproduction that I used a few times.
Mike
https://www.heartbeatcitycamaro.com/...M-3901098-USA/
The Following User Says Thank You to m22mike For This Useful Post:
ZLP955 (01-16-2020)
  #14
Old 01-16-2020, 04:57 PM
dvss1 dvss1 is offline
Napa used to carry the rotors. The last set I bought was in 2015. They were made in USA (at least it was on the box). Exact as originals too!
Old 01-16-2020, 05:34 PM
napa68 napa68 is offline
I'd even be inclined to check them (or take a light cut) on a brake lathe after all was pressed back together.
I started doing that with front drum brakes to eliminate any sort opportunity for a pedal pulsation.
Old 01-16-2020, 09:03 PM
ZLP955's Avatar
ZLP955 ZLP955 is offline
Mike
Thanks Mike, so you used both rotors and hubs? I wonder if they come already balanced.
Tim in NSW, Australia
Old 01-16-2020, 10:08 PM
m22mike's Avatar
I used them as a assembly as received. I see now reason to think that they were not balanced. I would be hesitant to use cheaper chine eezz rotors on a driver.
Mike
Old 01-16-2020, 10:40 PM
ZLP955's Avatar
Thanks Mike, would always spend up for quality brake and fuel system parts.
Old 01-17-2020, 05:39 PM
Jonesy's Avatar
Jonesy Jonesy is offline
NAPA sold 2 piece rotors?? The only ones I could get were 1 piece replacements.
I ended up buying an NOS set off this site
