Old 09-04-2019, 08:07 PM
Enoch Enoch is offline
Six nice original thermostatic choke coil covers. Three of them are restored and three of them are in Survivor condition. $15 each.
THE 3 RESTORED COVERS ARE SOLD
Old 09-04-2019, 08:11 PM
396 427 big block oil line to head clip and bolt. Original triangle stamp extremely nice condition with original vulcanizing clamp and ELH head marking bolt. They don't reproduce the original clamp correctly. $50 *************SOLD************
Old 09-04-2019, 08:16 PM
Original positive wire alternator boot very nice. $20 (X) ************SOLD************
Old 09-04-2019, 08:19 PM
Excellent original wire style distributor hold down and bolt
C headmarking bolt and raised pad retainer $20
Old 09-04-2019, 08:23 PM
Original big block short fuel pump mounting bolts, B&H head marking and L in a circle stamped fuel pump push rod plug. Very nice restored original pieces. $40 PP FF (X)
Old 09-04-2019, 08:27 PM
Early-mid 69 heater hose to alternator bracket mounting clamp and bolt. Clip is in very nice unrestored condition great for that untouched engine compartment. Not rusted just surface patina lots of paint still on it. Clip has AS stamp and the bolt is RBW head marking with self-cutting thread in the notch. $30 shipped to the lower 48 if paid with PayPal friends and family.
Old 09-04-2019, 08:30 PM
Super nice survivor small block wire loom clips for valve covers. Vulcanizing is in perfect condition, still has great original plating and actually some original paint on them. $20 for the pair shipped to the lower 48 if paid with PayPal friends and family. ************SOLD************
Old 09-04-2019, 08:34 PM
Original N40 power steering parts. I have 11 original nuts. You can tell the originals from the reproductions because the originals have the 6 hash marks on the top of the raised portion of the Locking flange. 11 nuts available $10 per nut.
I also have four original rubber hose wire clips. These are steel the reproductions are stainless steel and non-magnetic. This is a judged item, it shows and very hard to find originals. $25 each clip. PP FF
************2 SOLD / 2 REMAINING************
Old 09-04-2019, 08:41 PM
TCS wire clips. The one small clip holds the temperature sender wire on 70 Z28 and the two large clips are two different styles that hold the wire to the transmission to bellhousing mounting bolt on 4 speeds.
Z28 small clip is SOLD
Top left single loop Clip is SOLD
Remaining double loop clip is $25
Old 09-04-2019, 08:57 PM
396 427 454 4 bolt main large oil plug. W stamped. This goes into the one inch hole just above the oil filter. Very nice, very hard to find. $50. Ppff (X)
