Old 10-23-2018, 05:28 AM
Astock Astock is offline
Great buy on the car and engine.
How years was it, before GM had a higher performance sbc in a production car?
I remember looking at low mile '69 Z's in the '70's, with 1970 LT1 replacements. I would have done the same, with either rebuilding the original 302, or buying a crate LT1.
Old 10-24-2018, 06:51 PM
Looks like this one will be getting a set of Cragar's thanks to Sam Scardino. I'm thinking 8's and 4's will look good on this car.
Old 10-24-2018, 07:34 PM
No stock ride height on this car. Not for now anyways. I've got low profile tires for it if needed and also have shorter slicks as well. Wheel lips are already rolled, diff is centered and it has 275's tucked in it right now with no issues. Not really too concerned as I have a few sets of wheels and tires to play with and will find something to fit the rears. Thanks for the numbers in either case.
Old 10-24-2018, 08:45 PM
outlawperformance outlawperformance is offline
I'm running Cragar 15x4 fronts and 15x8 rears with custom offset with 4.75 BS with 275 drag radials. The car has stock multileaf springs diff is centered and have no issues. I took the upper shock shaft cover off it would rub.
The Following 4 Users Say Thank You to outlawperformance For This Useful Post:
Damien (10-24-2018), markinnaples (10-25-2018), Outlaw68Nova (11-30-2018), ScottG (01-25-2019)
  #55
Old 10-27-2018, 12:58 AM
Another picture that Gary sent me. From the 90's with the Welds on it.
Old 10-27-2018, 04:33 AM
Default Day II Deuce
Don here again. The custom black pinstriping and fogging was painted by another friend of mine, Ron Badiu, back in the early 70's. Ronnie Jr. has his own body shop here in Litchfield, Ohio.
The Following User Says Thank You to Flying Undertaker For This Useful Post:
NorCam (10-27-2018)
  #57
Old 10-27-2018, 02:41 PM
Don,
If you talk to Ron Badiu, can you ask if that was done over the original paint on the car? Except for the hood it would appear to have mostly original paint with some checking in a few places. I'm thinking the ghosting was done over lacquer and at some point it was clear coated?
Just curious what he may remember about the car and if it was ever repainted?
Old 10-27-2018, 08:42 PM
DW31S's Avatar
DW31S DW31S is offline
Killer car and the Cragars will look right at home. Love the '70s theme myself....
The Following User Says Thank You to DW31S For This Useful Post:
NorCam (10-28-2018)
  #59
Old 10-28-2018, 07:13 PM
Playing around with some wheels and tires today. I like the Torque Thrust rims myself and mounted these up with Firestone 5.60.15 front runners on 4" fronts, and a set of NOS Mickey Thompson H50/15's on 8.5" TT's. Thinking I'll drop the front springs and add an inch to the rear for some added clearance via Hurst Air Shocks. Then comes the vintage line loc, Lakewood roll bar and a few other goodies.
Just the start of things to come before the 383 Crossram and M22 go into this puppy.
Xplantdad (10-29-2018)
  #60
Old 10-28-2018, 07:49 PM
R68GTO R68GTO is offline
Looks great! I agree on dropping the front.
NorCam (10-29-2018)
