Old 02-24-2019, 10:07 PM
Enoch Enoch is offline
63 through 67 Corvette rear lower Valance mounting hardware. Correct original grade 2 rbw head marking bolts along with large flanged rbw head marking nuts. Perfect restored condition. $80 shipped to the lower 48 if paid with PayPal friends and family.
Old 02-24-2019, 10:42 PM
63 through 67 Corvette kick panel screws. 14 original excellent pieces. $80 shipped to the lower 48 if paid with PayPal friends and family.
Old 02-24-2019, 10:54 PM
67 Corvette 40 amp power window and headlight motor up down switch circuit breaker. Excellent original condition with original nuts. Great patina on the plating and littelfuse markings on Bakelite. $40 shipped to the lower 48 if paid with PayPal friends and family.
Old 02-24-2019, 11:11 PM
66 67 68 Corvette transistor ignition amplifier and harness mounting hardware kit. Included are three original unrestored TR head marking amplifier to Fender skirt mounting bolts with lock washers and nuts. 1 D head marking harness ground wire to radiator support mounting bolt and externally tooth star washer, one original rubber-coated J clip and D head marking mounting bolt for firewall and one original rubber-coated harness clip that attaches to the radiator support and holds the harness in place. Excellent original pieces that are very difficult to find and source. $120 shipped to the lower 48 if paid with PayPal friends and family.
Old 02-24-2019, 11:25 PM
63 through 67 Corvette Hood prop mounting bolt kit. The two flat and bolts with the captured lock washer attached to hood prop to the hood while the two pointed tip bolts with captured flat washers attached the hood prop to the fender skirt. Excellent original restored pieces. $60 shipped to the lower 48 if paid with PayPal friends and family.
Old 02-24-2019, 11:40 PM
64 through 74 Corvette shifter to shifter bracket mounting bolts. Long bolt has CP head marking uses the internally tooth star washer while the short bolt has TR head marking and uses the lock washer. Excellent unrestored original pieces. $30 shipped to the lower 48 if paid with PayPal friends and family.
