Old 02-09-2019, 11:01 PM
Default Misc Rare / Hard Camaro Parts
1. Mint 67-69 Camaro Nova LH & RH Lower NOS Control Arms.....Sold
2. 621 Aluminum Bell with Assembly Line Inspection Cover.....Sold
3. January 69 AM Radio $275.00
4. 733 Dated A 12 9, 11 inch Flywheel that is in excellent shape $175.00
5. Original 4spd application flat bottom Cowl Induction Air Cleaner $1500.00.....Sold
6. 1969 Camaro Z28 Yenko YH Rim Dated Feb 26, 1969 (Set of Four)......Sold
7. 67 68 Camaro Z28 or SS 4K L78 Rear Clutch and Fan.........Sold
8. 1969 Camaro Rally Sport Very Rare GM New Old Stock Actuator Shields ( LH and RH) NOS Actuator Shields $750.00
9. Mint 69 Z28 Lower Crank Pulley $350.00
10. 67-69 Camaro Rear Short Seat $400.00
11. Pair of February 633 Front Disc Brake Calipers Dated 52nd Day $350.00.......Sold
12. (4) DF Rims with the Large Upside Down DF Stamp.........Sold
13. 418 Aluminum Finned Valve Cover without drippers (Pair) $650.00
14. Mint Full Original Endura Bracket Set (Four Pieces) $500.00
15. Brake Booster Tower Stand....... Sold
16. Nice used original black 69 dash cluster......Sold
17. A used set 14x7 Trim Rings with correct 4 clips $75.00 ea
18. 69 Z28 or 67 Corvette (3) sets of 15x7 Trim Rings with correct 4 outer clips $400.00 a set of (4)
19. 69 Camaro Black Door Jamb Windlace )_Nice no Clips) $350.00
20. 403 Aluminum Bellhousing for a 10 1/12 inch Flywheel $100.00
21. Original Hurst Shifter $350.00
22. 4 Spd two hole Reverse Lockout $350.00.......Sold
23. Original Three wire separator Clover leaf for Spark Plug wires $45ea.
24. 798 Muncie Tag M21 $125.00.......(Sold 1 and have 1 left)
25. 356 Muncie Tag M20 $100.00
26. 67 / 68 4 Spd Radiator OD and IF Tanks $200.00 (Dated "A" January)
27. Rare 69 Camaro Big Block Throttle Rod $400.00
28. (8) Used Original Battery Hold down Bracket $60.00 ea.
29. (4) Dill Original Valve Stem Caps $400.00 .........(Sold 1 set and have 1 set left)
30. (4) Schrader Valve Stem Caps $400.00 ...........(Sold 1 set and have 1 set left)
31. 67-69 Original Assembly Line Small Block Oil Pressure Brass Fitting $175.00
32. Original 69 Camaro Offset Yoke Driveshaft $350.00
33. Complete Set of NOS Subframe Bushings $475.00 (Sold 1 and have 1 left)
34. 403 Bellhousing $100.00
35. NOS 4Spd Trans Mount........Sold
36. 69 Z Vacuum Hose Smog Tee $75.00
37. 9204 Brake Booster Dated 120th Day $375.00.....Sold
38. Used 1967 Alternator Deep Groove Pulley #3829387-AI $125.00
39. Original Mint 856 Smog Pulley...........Sold
40. Original Mint 1105 Power Steering Pulley......Sold
Shipping is buyer's responsibility
Many other Rare Camaro Parts and NOS Stuff to follow
67 Z/28 Butternut Yellow
69 Z/28 Rally Green
69 Z11 Pace Car
2010 2SS RS Aqua Blue
68 Z/28 Lemans Blue
C7 Corvette
68 SS Lemans Blue
Old 02-09-2019, 11:59 PM
302moz 302moz is offline
Default Parts
Will you sell individual parts or just the whole list? Thanks
Old 02-10-2019, 12:49 AM
Niblet Niblet is offline
Banned
is item 33 (Subframe bushings?)for a 67 Camaro as well? were they all the same P/N's?
I am interested if they are
Old 03-01-2019, 01:01 AM
Updated List
69 Z/28 Rally Green
69 Z11 Pace Car
68 Z/28 Lemans Blue
C7 Corvette
68 SS Lemans Blue
The Following User Says Thank You to luv2sixty9 For This Useful Post:
Copo_Cartel (03-01-2019)
Old 03-03-2019, 11:12 PM
Bump
69 Z/28 Rally Green
69 Z11 Pace Car
68 Z/28 Lemans Blue
C7 Corvette
68 SS Lemans Blue
Old 03-04-2019, 01:42 AM
luzl78 luzl78 is offline
Do the control arms have the balljoints riveted in?
Old 03-04-2019, 10:53 AM
No the balljoints are pressed in. Only the uppers were riveted and these are lower control arms.
69 Z/28 Rally Green
69 Z11 Pace Car
68 Z/28 Lemans Blue
C7 Corvette
68 SS Lemans Blue
Old 03-04-2019, 11:54 AM
Blown32's Avatar
Blown32 Blown32 is offline
PM sent
Old 03-04-2019, 05:03 PM
Oh that’s right. Thanks
Old 03-08-2019, 10:22 PM
Sale Pending, but I'm posting some pics here for other members to view that requested them in case the deal doesn't materialize for I have patiently been waiting over two weeks.
They all have the same dates, condition and beautiful lug nut holes.
69 Z/28 Rally Green
69 Z11 Pace Car
68 Z/28 Lemans Blue
C7 Corvette
68 SS Lemans Blue
Tags
302 dz mo z28 yenko copo
