Old 10-18-2019, 12:56 AM
cdn454LS6 cdn454LS6 is offline
Default Speedo reducer what's it for
Anybody know what this reducer is for ?
666F V8
.9444W
Thanks for your help
Ken
Attachments - The Supercar Registry IMG_1955.jpg IMG_1954.jpg IMG_0989-1.JPG IMG_0987-1.JPG
Old 10-18-2019, 01:29 AM
McCune McCune is offline
Low Rear Gear cars.
Old 10-18-2019, 01:31 AM
XXXGoldL34M20's Avatar
My Guess later model Truck after 1970 with 4.10 gear ratio.
Checked eBay completed items and one sold for $64 but had no info at all for what it was for.
Old 10-18-2019, 01:34 AM
There are charts from GM that show when a particular combination of trans and wheel-tire size got a particular part number reducer. The part number is not one of the numbers you listed. you have to do a bit of google searching to cross reference the GM part number to the reduction number, in your case the .9444.
Here's an example for a 1970 Camaro,Chevelle, Nova 4 speed cars:
http://www.gmpartswiki.com/getpage?pageid=12662
If you plan on actually using it, you would be advised to open it up and clean out and re-pack the grease. It dries out over time.
Owned since 1978 - First Car
The Following 3 Users Say Thank You to BCreekDave For This Useful Post:
Niblet (10-21-2019), PeteLeathersac (10-18-2019), ZLP955 (10-19-2019)
Old 10-18-2019, 03:18 AM
I found one guy selling a reducer
and claiming it's for LS6 410 rear
666F V8
.8241C
maybe mine is for 456 rear ?
Old 10-18-2019, 02:32 PM
A friend here in Calgary gave me one that I used in the green 4:10 gear car I recently finished. They work well if you know what gear conversion they were intended for.
Old 10-18-2019, 08:12 PM
L78steve L78steve is offline
If you repack it with grease use a light grease. Otherwise the load can snap the tab on the drive gear clip inside the tail housing.
The Following User Says Thank You to L78steve For This Useful Post:
Old 10-19-2019, 02:39 AM
hiperf406 hiperf406 is offline
Are these also used on the automatic cars, mine came with 4:10 gears but someone put in 3:73 gears. If I return to the factory gears I will have to get a reducer.Thanks
63 Vette Rdstr (sold )
68 Z28 (May /68 build)
70 LS6 Hdtp.M40.4.10/Dec/69 build
When the flag drops the bullsh1t stops.
Old 10-19-2019, 10:21 AM
Igosplut's Avatar
Igosplut Igosplut is offline
I have a box full of those, there was two different kinds. Mostly for trucks.
WOT
Old 10-19-2019, 11:33 AM
WILMASBOYL78's Avatar
Post Speedo Reducer...
Yes auto cars got these as well.
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
The Following User Says Thank You to WILMASBOYL78 For This Useful Post:
HuggerSS (11-20-2019)
