Old 12-07-2019, 08:59 PM
Enoch Enoch is offline
Original assembly line installed white stripe vacuum / smog hose. 18.5 inches long. $50 (X3)
(#80)
Old 12-07-2019, 09:01 PM
Original assembly line installed white stripe vacuum hose. Also used for smog. 33 + 1/2" Long. $60 (X3)
(#81)
Old 12-07-2019, 09:03 PM
Original assembly line white stripe smog / vacuum hose. 21 in Long. $ 45 (X3)
(#82)
Old 12-07-2019, 09:05 PM
Original white stripe vacuum smog hose. 27 inches long. $50 (X3)
(#83)
Old 12-07-2019, 09:12 PM
Intake manifold stud, has various applications, one is for the TCS solenoid and vacuum advance line clip, the other is for 396 Z16 and L 78 Corvette fuel filter and also fuel injected Corvettes. Original short and stud on the top with dimple. $20. Ppff (X)
(#15)
************SOLD************
Old 12-07-2019, 09:17 PM
Original translucent Danco stamped rear end vents. The repros have a green cap to them. These both are in very nice condition. $15 each. Ppff (X)
(#53)
Old 12-07-2019, 09:19 PM
Excellent restored smog pump pulley bracket bolts with RBW head marking and diverter valve mounting bolts with RSC head marking. As nice as you're going to find. $35. PP FF (X3)
(#59)
Old 12-07-2019, 09:23 PM
Original plastic spark plug wire stand looms. $20 each. **********SOLD*********
Old 12-07-2019, 09:26 PM
66-67 Nova Impala GTO
67 Camaro
67-69 Corvette
W stamped rear end fill plug and posi traction only label. Extremely hard to find originals. $75. Ppff (X3)
(#103)
Old 12-07-2019, 09:30 PM
sold
