Old 02-26-2025, 01:49 AM
OneStopRestoration OneStopRestoration is offline
Default Heads, Gaskets and Intake
Heads recieved enough decking to get the huge 074 chambers down close to the original 842s. With super thin cometic gaskets and head work compression came in at 10.8 to 11.0 :1 accross the pistons.
Next part gets a bit tougher. With that much machining on the heads this sinks the bolt holes for the intake further downward in the engine. This then means the intake holes no longer line up and you cant put the bolts in.
The Following 3 Users Say Thank You to OneStopRestoration For This Useful Post:
Dave Rifkin (02-27-2025), dykstra (02-26-2025), mhurd (02-26-2025)
  #262
Old 02-26-2025, 01:53 AM
Default Intake Machine Work
I had to start this project with building a fixture plate to hold the intake on the mill. Not to terribly hard but turned out great. From there the intake can be positioned so that it can then be indicated in to cut the right amount of the material off the intake front to back and from top to bottom of the runners to fit near perfectly on the engine.
Once the mating sides of the intake are cut it re aligns the bolt holes, but now you have the issue of little to now front and back wall clearance. Once again a fixture had to made to hold the intake flat to the table for the front and rear intake walls to be fixed and re machined to match the block.
The Following 13 Users Say Thank You to OneStopRestoration For This Useful Post:
66BoxNova (02-26-2025), Crush (02-26-2025), Dave Rifkin (02-27-2025), dykstra (02-26-2025), L78_Nova (02-26-2025), mhurd (02-26-2025), olredalert (02-27-2025), ragtop (02-26-2025), RPOLS3 (03-02-2025), SMS (03-03-2025), SuperNovaSS (02-27-2025), Tenney (02-26-2025), Zman1969 (03-14-2025)
  #263
Old 02-26-2025, 10:40 AM
dykstra's Avatar
dykstra dykstra is offline
WOW Rick! Engine is looking great! Can’t wait to hear it!
Dave Dykstra
NCRS#66003
you. – Jeremy Clarkson.
Dykstra Motorsports
OneStopRestoration (02-28-2025)
  #264
Old 02-26-2025, 09:21 PM
Tuna Joe Tuna Joe is offline
That’s next level stuff right there!
The Following User Says Thank You to Tuna Joe For This Useful Post:
  #265
Old 03-02-2025, 11:17 PM
RPOLS3's Avatar
RPOLS3 RPOLS3 is offline
Impressive work.
Jake Dykstra
Dykstra Motorsports
Old 03-14-2025, 12:20 PM
Zman1969 Zman1969 is offline
I just went through this same deal on my L78 nice work on this car!
69 RS/Z 302 VE3 Daytona
69 Chevelle SS 396 375
69 T/A clone LS6/6 speed
90 Formula 350
Old 03-14-2025, 06:36 PM
Default Engine heat cycled on the run in Stand
Im not sure how it goes everyone else but things never go smooth and you really cant trust a single new part you buy.
Had the motor on the stand and it would fire a few cylinders but just wouldnt kick off. changed the coil, check the spark at the plugs which looked weak and then decided to change out the points that had the condesnor intergrated in. Put in one with separate points and condensor. Both sets were AC Delco.
All and all im very happy and frankly impressed with the throttle response and how it runs and sounds.
https://youtu.be/JtRLdeaSxf4
The Following 7 Users Say Thank You to OneStopRestoration For This Useful Post:
dykstra (03-15-2025), McCune (03-14-2025), mhurd (03-14-2025), napa68 (03-15-2025), olredalert (03-14-2025), Tuna Joe (03-15-2025), Zman1969 (03-17-2025)
  #268
Old 03-14-2025, 07:10 PM
SMS SMS is online now
Sweet runner. Thanks!
The Following User Says Thank You to SMS For This Useful Post:
OneStopRestoration (03-16-2025)
  #269
Old 03-15-2025, 01:40 AM
The Uni-points were a known piece of crap in the late seventies, at repair shops. But I'm thinking you weren't even born yet to have heard about that...
napa68 (03-15-2025)
  #270
Old 03-15-2025, 08:30 PM
Default Off the Stand and Into the Chassis
Didnt feel like wasting any time. Got the engine off the run stand and into the chassis. Finsih up clutch, belhousing, transmission, and driveshaft. Then back to body work. Maybe I will setup a lemondae stand to pay for the exhaust.
The Following 16 Users Say Thank You to OneStopRestoration For This Useful Post:
66BoxNova (03-16-2025), Dave Rifkin (03-16-2025), dykstra (03-16-2025), jer (03-16-2025), L78_Nova (03-17-2025), L_e_e (03-16-2025), mhurd (03-15-2025), napa68 (03-15-2025), olredalert (03-15-2025), ragtop (03-16-2025), RPOLS3 (03-16-2025), scuncio (03-15-2025), SMS (03-17-2025), Tenney (03-16-2025), Tuna Joe (03-31-2025), Zman1969 (03-17-2025)
