Old 10-12-2019, 04:46 AM
Damien Damien is offline
Default Bits and Pieces
Looking for some small stuff for my '69 Chevelle if anyone can help?
Correct throttle bracket 396 w/ Quadrajet #3992376
Q Jet carb stud & wing nut
1/4" & 3/8" pinch clamps
Filter bracket
Correct PCV hose
TIA
1969 SS 396/350 Chevelle
Old 10-12-2019, 01:03 PM
ALLZS ALLZS is online now
I should have the pinch clamps how many do you need
The Following User Says Thank You to ALLZS For This Useful Post:
Damien (10-13-2019)
Old 10-12-2019, 07:27 PM
Enoch Enoch is offline
If you let me know length and configuration on the Quadrajet carb stud I probably have it. And I definitely have the Wingnut
The Following User Says Thank You to Enoch For This Useful Post:
Damien (10-13-2019)
Old 10-12-2019, 09:22 PM
X66 714's Avatar
X66 714 X66 714 is online now
The pcv hose can be ordered from Doc Rebuild, The Corvette guy. Ribbed & curved...Joe
Damien (10-13-2019)
Old 10-13-2019, 12:21 AM
I will take 6 of each if you have them?
Old 10-13-2019, 12:26 AM
Apologies Rich, I probably should have been clearer, the stud I am chasing is for the air cleaner. Is there a variation in these?
Old 10-13-2019, 01:30 AM
Damien,
Looking Great!
You also need a Cowl Seal and the correct metal clips....and those plastic Cowl Covers were never on any 1969 Chevelle.
Also run your orange heater blower wire on the Bottom side of your heater.
It’s coming along nicely. Keep up the great improvements.
Old 10-13-2019, 08:44 PM
Thanks Dan.
It had a rubber cowl seal on it but I took it off. Pushes the rear of the hood up.
It needs a foam seal.
Old 10-13-2019, 11:32 PM
Originally Posted by Damien View Post
Thanks Dan.
Damien,
My hunch is that the former car owner purchased a reproduction Cowl Seal from Ground Up, Inc.
I know this because the former owner worked part time for Ground Up. Or you may have an early style reproduction hood which has now been redesigned better. Their early reproduction hoods were notorious for sticking up in the back.
What you need is an original Cowl Seal
Old 10-14-2019, 01:08 AM
Dan,
Original seal, as in NOS? Or original as in design?
Carb stud and wing nut sorted.
The big things for me are the throttle bracket and filter clamp.
