Old 09-16-2019, 03:44 PM
Tracker1's Avatar
Tracker1 Tracker1 is online now
Default 1970 Camaro large opening rad support
Need two, good used or repairable (minor metalwork) considered. Yes, I need two (2). LARGE OPENING.
These came on HD-radiator-equipped cars
AC cars
Z28s
And some big-block applications
Thank You in advance.
I ain't nobody, dork.
Attachments - The Supercar Registry Screen Shot 2019-09-16 at 12.36.31 PM.png
Old 09-16-2019, 04:43 PM
Tracker1's Avatar
Here are the unique identifying features of the this rad support. Red arrow indicates wide mouth 25" opening. Yellow arrow indicates hole for AC pipe for AC equipped cars - the rad support would have this hole regardless of AC-equipped or not. We have a 1970 L78 and a 1971 RS Z28 in need of these supports. Pictures courtesy of ronzz572 Thanks.
Old 09-16-2019, 07:23 PM
Ricks72Z28 Ricks72Z28 is offline
Default 1970 Camaro HD Radiator support
FYI... the NOS ones I have seen were always the small opening with instructions to open it up for the HD application. The other issue was they were never stamped with the large opening for the AC.Good luck with your hunt...
1970 Camaro
1972 Z28,
1973 Corvette L82,4 speed
1974 Z28 LT,M20,AC,18k Original Miles
2007 Ford Shelby GT500 40th Anniversary
Old 09-16-2019, 09:57 PM
Mulsanne Blue Mulsanne Blue is offline
Default Rad Support
If you know measurements of the hole location and its diameter, they sell hole dies that can radius the opening.
Old 09-17-2019, 02:11 AM
ronzz572 ronzz572 is offline
The hole is actually stamped out and would be difficult to replicate. Not saying it couldn't be done. I will keep a look out for you Tracker1. And you're welcome on the picture you posted.
1970 z28 4speed cranberry red white stripes standard saddle interior.
Old 09-17-2019, 02:34 AM
ruralrte66 ruralrte66 is offline
I have a 1970 A/C and it reads 26 3/8 across , were they all cut different?
Gregg
Old 09-17-2019, 02:52 AM
Tracker1's Avatar
Gregg
25-26 inch yeah...is it for sale?
Old 09-18-2019, 01:16 AM
https://www.eastwood.com/eastwood-pu...ring-dies.html
Old 09-18-2019, 01:58 AM
Now that tool will do the job. It could be used to convert a NOS to a OEM.👍
Old 09-18-2019, 12:46 PM
Tracker1's Avatar
Whats the measurement on that hole Ron? The little round one...
