WTB: 70 L78 chevelle
Still on the elusive hunt for the L78 4 speed Chevelle. Fathom Green in a lucky world. Survivor or needs resto. Hope everyone is doing great. Sean
70 LS 6 4 SPEED CHEVELLE 69 SS 396/375 HP 4 SPEED CHEVELLE 68 SS 396 CHEVELLE SS 396/375 4 SPEED 69 COPO CHEVELLE 4 SPEED #S MATCH 69 COPO CAMARO #S MATCH SURVIVOR (BLACK) 69 COPO CAMARO (BLACK) 55 GASSER L88 4 SPEED 66 NOVA "UNDER CONSTRUCTION" 70 440 SIX PAK CHALLENGER SUPER STOCKER 2001 RVW/LDR TRANS AM 1020" BBC 8 SYSTEMS |
https://bringatrailer.com/listing/19...evelle-ss-128/ look at the build steet.
The Following User Says Thank You to Jimlt4383 For This Useful Post: | ||
Bill Pritchard (05-31-2023) |
From the auction wording: "The factory L78 396ci V8 was removed under previous ownership." Also, from the seller on BaT: "The original motor is not available. Was not obtainable when I got the car."
Bill Pritchard 73 Camaro RS Z28, L82, M20, C60 |
The Following User Says Thank You to Bill Pritchard For This Useful Post: | ||
Sean (06-02-2023) |
That really is a shame to me. The car if real deserves the original drivetrain. Sean
Being a 70 L78, I’m shocked it only brought $53k. That’s my old car which I bought as an SS without documentation, had a really nice “day 2” look to it. I noticed the single fuel line and a few other tells and took a chance on it. I personally found the build sheet under the tar paper and got the car added to Dale’s registry. The tach is a factory error as its ink stamp corresponds to the build date of the car. The build sheet calls for a 983 tach, but got a 938 tach instead (small block redline). The part numbers make it easy to mix up. FWIW, I’ve seen other solid lifter Chevelles with the same tach error. I should have never sold that one. Just my 2 cents
The Following 8 Users Say Thank You to GotGrunt For This Useful Post: | ||
67 Nova Boy (07-07-2023), Big Block Bill (07-07-2023), John (07-11-2023), L_e_e (07-06-2023), markinnaples (07-12-2023), olredalert (07-07-2023), RPOLS3 (07-06-2023), scuncio (07-06-2023) |
----Red Alert had the very same mistake with the Tach!....Bill S
The Following User Says Thank You to Richls5 For This Useful Post: | ||
GotGrunt (07-06-2023) |
"The build sheet calls for a 983 tach, but got a 938 tach instead (small block redline)"
Having dyslexia, this is an issue that would be VERY easy to get wrong. Be interesting to know if all the cars mentioned with this error were assembled at the same plant...
The Following User Says Thank You to Too Many Projects For This Useful Post: | ||
dustinm (07-07-2023) |
Still looking for one. Did find an auto L78 black/white stripes with white ivory interior. Buildsheet. Needs restored.
Thread Tools | |
Display Modes | |
