Old 08-10-2012, 11:34 PM
Chevy454 Chevy454 is offline
Default Urgent: coil/starter wiring help
Trying to get the yelow sub put back together...had been running an msd setup (going pertronix) so it was all different and I've forgotten how it was originally, lol.
Anyway, on the starter, the heavy purplish wire goes on the r terminal and the lighter yellow wire goes on the s terminal?
But on the coil, ive got a brownish wire with a spade terminal, a yellow wire with a spade terminal, and a tanish white wire with the end broken off that feels different than the others (resistance wire)? I need yellow and resistance wire on + side of coil? For some it wont crank a bit...
Old 08-10-2012, 11:39 PM
Default Re: Urgent: coil/starter wiring help
Heres a crappy picture...
Old 08-11-2012, 12:03 AM
m22mike's Avatar
m22mike m22mike is offline
Rob
Starter wires you got right. On the coil + terminal "yellow wire and the resistance wire" with the cloth insulation. On the - terminal "brown tach signal and a black wire from the dist"
If it does not crank, maybe another problem.
Mike
Old 08-11-2012, 12:28 PM
sYc sYc is offline
Called Mo...had the wires a$$-backwards on the starter. Onc wired correctly, fired right up, sounded good...now to the track to see if we did any good.
Tom Clary
Old 08-11-2012, 12:44 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: sYc</div><div class="ubbcode-body">...now to the track to see if we did any good. </div></div>
Wow. That the best news I've heard in a while! [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img] [img]<<GRAEMLIN_URL>>/beers.gif[/img]
Fingers crossed for you at the track!
Drive that bitch like it needs to be driven!
Peter
Pete Simpson 1962-2013 RIP
Owen Simpson
Eric Simpson
