Old 11-01-2017, 12:52 AM
WILMASBOYL78's Avatar
Post Th-400...
You can move that shift point up by changing the governor or modifying springs/weights...I may have a hi-shift point unit in the parts. dept if you are interested
-wilma
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
Old 11-15-2017, 12:43 PM
Markyodb2 Markyodb2 is online now
Does anyone know the stall on the CX 69 TH400?
Old 11-15-2017, 01:22 PM
I believe 2200 RPM.
Old 01-27-2019, 09:47 PM
Fast67VelleN2O's Avatar
Is it possible for a 1970 CW transmission to have no partial vin number?
Day 2 is Life.
Old 01-28-2019, 12:56 PM
Post CW coded TH400..
I have seen the partial VIN in 2 locations;
1..on the top side of the pan frame rail, driver's side above shift lever.
2..on the passenger side of the bell housing near the top
most have been in the frame rail location....you will need to have tranny out of the car or have a good mirror/lite to see either location.
**this tranny was only available in the L78 Nova/Chevelle and the LT1 Deuce and Z28. There is typically a pink CW ink stamp on the trans. case.
-wilma
02 Berger 380hp #95
Lots of L78 Novas
70 Orange Cooler
69 Camaro
Old 01-28-2019, 10:00 PM
-wilma
I looked all over and did not find a vin stamped anywhere. Here's the tag for reference. I'll be listing it for sale soon I guess.
Day 2 is Life.
Old 01-29-2019, 05:53 PM
Given the date code of '478'...this was a unit built in April of 1970. Most likely an L78 Nova application...but, could be from a Z28...Deuce would be a long shot. Not sure if they had CW trannys available over the counter...but, if so there would still be an assembly stamp someplace..
do you have the 6 lug converter...??
Here are some images of partial VIN by pan rail...
02 Berger 380hp #95
Lots of L78 Novas
70 Orange Cooler
69 Camaro
Old 01-29-2019, 06:16 PM
I found the vin this morning when it wasn't so dark out. Its a 1970 Camaro transmission. There is no converter. Vin was stamped right on the bell housing flange edge, near where the oil filter mounts.
Day 2 is Life.
Old 01-29-2019, 08:39 PM
Norwood or Van Nuys?
Old 01-29-2019, 09:15 PM
Norwood.
Day 2 is Life.
