Old 09-05-2018, 10:54 PM
Danzo Danzo is offline
Default 69 Camaro smog pump finish
Anyone have any success trying to replicate the finish on the housing? If so details please.
Thanks, Doc.
Old 09-13-2018, 12:13 AM
C'mon guys,nobody has tried this?
Old 09-13-2018, 01:14 AM
I would think it is exactly the same procedure as an alternator case. They are both cast aluminum
Old 09-13-2018, 01:52 AM
I cleaned up my Nova pump with a grey (fine) scotch brite pad and lacquer thinner. Then went over it with 0000 steel wool.
69 El Camino
69 Nova
C7 Vette
Old 09-13-2018, 03:11 AM
MosportGreen66's Avatar
Send it to Bill Hodel
Old 09-13-2018, 03:26 AM
jl8z28 jl8z28 is offline
And pay big bucks i can do it cheaper
Old 09-13-2018, 10:45 AM
pm sent
Old 09-13-2018, 05:16 PM
McCune McCune is offline
I know it is not what some like but here is what I can make a pump look like.
Old 09-13-2018, 06:44 PM
m22mike's Avatar
m22mike m22mike is offline
If I could ask, how did you get the front bearing out without trashing the case, and how are you going to retain the new front bearing ?
Thanks Mike
Old 09-13-2018, 10:57 PM
Thanks Mike
I just press out the shaft with the bearing and then used green loctite sleeve retainer on the bore and new bearing.
The Following 3 Users Say Thank You to McCune For This Useful Post:
CamarosRus (01-23-2023), L16pilot (09-13-2018), m22mike (09-13-2018)
