Old 03-30-2020, 10:01 PM
Default Ansen valve covers
I'm trying to make an old set of Ansen valve covers look good again, but it just isn't working out. After a lot of cleaning, sanding, brushing and polishing they still look bad. I'm thinking of sand blasting them and running them that way. I had a set of these many years ago on my '67 Chevelle SS and I blasted and painted them flat black. They looked pretty good for a kid that didn't have any money. What do you thing about the satin aluminum look for these valve covers? The tunnel ram in this picture was also polished and I had it blasted.
Attachments - The Supercar Registry small 427.jpg norek2.jpg norek0.jpg norek.jpg
Old 03-30-2020, 10:29 PM
R68GTO R68GTO is online now
Freddie, I glass bead-blasted these vintage Holley's - I liked the way they turned out.
big gear head (03-31-2020)
Old 03-30-2020, 10:39 PM
GrumpyJeff's Avatar
GrumpyJeff GrumpyJeff is offline
yep , Glass beading is the way to go ! I do all my old aluminum OEM Harley motor/trans parts
The Following User Says Thank You to GrumpyJeff For This Useful Post:
Old 04-04-2020, 01:41 AM
I got them blasted and I think they look all right. I'm still not completely happy with them, but they will do, for now anyway.
Old 04-04-2020, 05:07 AM
I bead blasted a pair years ago and then hit them with some 00 steel wool and a green Scotch Brite pad for a couple of hours. They turned out really nice and the after-work gave them a clean rubbed down look that was less porous looking.
big gear head (04-04-2020)
Old 05-09-2020, 06:53 PM
1971ls6's Avatar
1971ls6 1971ls6 is offline
What he said, clean stains with brake cleaner
Old 04-04-2020, 12:58 PM
They're awesome Freddie also everything else lookin' good too!
Sorry if I missed it before but love to hear more of this engine and where it's heading.
Are the heads alum or painted steel and what block/parts also trans/rear axle?
Old 04-04-2020, 03:43 PM
Bernhard Bernhard is offline
Has anyone tried soda blasting or vapour blasting.
Some like the finish of vapour blasting on aluminum as it appears more original than glass bead.
69 442 post bench 3 pedal
Old 04-04-2020, 03:47 PM
Here is a video clip
Glass and Vapor blasting differances
https://www.youtube.com/watch?v=KqHcSVLB9fw
Old 04-04-2020, 04:45 PM
Pete, this is the same engine that's been in my car since the late '80s. It's a bowtie block with a 6223 crank. A few years ago I swapped the LS6 rods and TRWs for a set of Molnar rods and Diamond pistons. It's a solid flat tappet cam with around .605 lift. The heads are 077 aluminum. If you look close you can see the snowflake above the number 2 exhaust port. I have been running a Holley strip dominator with a 850, but decided to go for a different look this year. I don't expect it to make any more power this way, but I've always wanted to look at the back of a tunnel ram while driving down the road.
I'm using a new AutoGear N24 transmission this year, and the rear end is a 9 inch. I haven't updated this in a while, but most of it is here. https://www.yenko.net/forum/showthre...ight=gear+head
The Following 2 Users Say Thank You to big gear head For This Useful Post:
NorCam (04-04-2020), PeteLeathersac (04-05-2020)
