Old 02-15-2020, 02:30 PM
scuncio scuncio is online now
Default Rough '69 Camaro Project, Interesting Options
I'm intrigued that this car, with all the obvious hackery, still has a 1969 blue-light four speaker stereo in the dashboard. Makes me wonder how it was originally ordered.... Even the 4-speed pedals and shifter reinforcement ring look way wrong.
Check out the floor from underneath - yikes.
Link to 1969 Camaro Project Car auction
124379N548787
Old 02-15-2020, 02:54 PM
Jonesy's Avatar
Jonesy Jonesy is offline
If that's the original tunnel, its not an original 4 speed car. Look like a auto with console car. You can see the shifter hole is wrong and the auto trans cable hole is there.
Old 02-15-2020, 05:44 PM
Lynn Lynn is online now
I was getting ready to post the same thing.
One of the pics from the underside makes me beleive it may not be the factory tunnel.
Old 02-15-2020, 05:58 PM
Kind of wondering what the rear subframe is even attached to? Looks like the floor pans are just sitting in there. Jacking up on the subframe seems like a sure way to bend up the front sheet metal.
Owned since 1978 - First Car
Old 02-15-2020, 08:21 PM
Kurt S Kurt S is offline
Kurt S - CRG
Old 02-18-2020, 03:09 PM
HawkX66's Avatar
HawkX66 HawkX66 is offline
If you look close, it looks like someone just screwed a trim piece to the original tunnel. A lot of people think the jagged edges of an original assembly line torch cut hole isn't factory.
edit: just noticed the two rivnuts and the shift cable hole from an auto are there. Yup, auto tunnel.
-Dave
Semper Fi!
69 Camaro SS396 L34 X66
Old 02-22-2020, 12:16 PM
chris slawski chris slawski is offline
So only the automatics got the cable hole? As opposed to it being part of the floor pan stamping itself?
Chris Slawski
69 Nova
69 Malibu
69 Camaro RS
69 Camaro SS 396
Old 02-22-2020, 01:34 PM
bergy's Avatar
bergy bergy is offline
yes - only console automatics got the cable hole
chris slawski (02-23-2020)
Old 02-22-2020, 05:16 PM
Canuck's Avatar
Canuck Canuck is offline
Pedals are from a later nova or Malibu 78-83
www.vancouverclassiccars.com
Old 02-24-2020, 02:57 PM
HawkX66's Avatar
Correct. I believe there is a locating dent in the stamping so they knew where to punch the hole. The hole is a clue, not definitive. I know my father punched the hole in my 69 when he converted it to an auto so he could drive it.
This ugliness is my original tunnel.
-Dave
Semper Fi!
The Following User Says Thank You to HawkX66 For This Useful Post:
chris slawski (02-24-2020)
